34.5°W Intelsat 35e <America>
  • Hi aspirepy,
    I'm curious, what does the signal spectrum look like from the satellites you receive in your area, like this one, at 34.5W or others?
    Thanks :3:
  • Hi aspirepy,
    Thanks :3:
    Hola amigo, gracias por comunicarte conmigo!!, lo aprecio muchísimo por la admiración que te tengo, te envío esta imágenes, no sé si te servirán ojalá que si, estoy a tus órdenes!
  • 3851 R 7500
    DVBS2 8PSK FEC: 2/3
    MPEG4/4.2.0
    Receptor: TBS 5522SE/Estado del tiempo: soleado
    Id.: PAULISTAO PLAY
    Fútbol Masculino
    Campeonato Paulista Sub-20
    FC SKA (Osasco Futebol Clube) Brasil vs. Sao Paulo
  • Hi guys,
    I have been watching the signals here more closely since the weekend in the hope that these would be from the global beam. Personally, however, I believe that aspirepy has captured feeds from the C-band spot beam for South America.
    @aspirepey catches in spectrum between 3.80 to 3.86 GHz looks different as mine - as far as I can see. :3:
  • 3817 R 7500
    DVBS2 8PSK FEC: 2/3
    MPEG4/4.2.0
    Id.: PGM TITULAR
    Fútbol Copa Paulista 2022/Final Ida
    XV de Piracicaba vs. Marilia
  • Just checked 3817 R - no signal here in Europe.
    aspirepy
    probably you read this here - can you re-check if the feed is still on?
    :72: /edit: FYI: Starting a new toppic for this "Americ" beam. Click for "Global" beam toppic here!
  • 3817 R 7500
    DVBS2 8PSK FEC: 2/3
    MPEG4/4.2.0
    Id.: COPINHA
    Fútbol Masculino
    Copa Sao Paulo de Futebol Junior (Sub-20)
    Paraná vs. Vitória
  • mismos parámetros, distinto ID:
    3817 R 7500
    DVBS2 8PSK FEC: 2/3
    MPEG4/4.2.0
    Id.: AMERICUP MAIN
    Fútbol Masculino
  • 3827 R 7500
    DVBS2 8PSK FEC: 2/3
    MPEG4/4.2.0
    Id.: SERVICE 1
    Fútbol Masculino
    CSA vs. Bahía (terminando)
  • 3817 R 7500
    DVBS2 8PSK FEC: 2/3
    MPEG4/4.2.0
    Id.: SERVICE 1
    Fútbol Masculino
    Nacional vs. Alecrim
