30.9°E Türksat 5A
  • Hier ein horizontaler Scan auf 30.9E im High Ku-Band, vertikal folgt noch.
    Kein Transponder wurd automatisch gelockt, alles manuell gesucht.
    13170, 13331, 13616, 13684, 13822 und 13918 weisen höhere Symbolraten auf, die anderen sind unter 1000
    180 Laminas mobil (all)
  • Beim vertikalen Scan liegen 13048, 13084, 13426, 13825, 13832 und 13848 mit den Symbolraten über 1000.
    Sofern dieser Frequenzbereich überhaupt für öffentliche Zwecke gedacht ist, dürfte das Empfangsgebiet ausschließlich die Türkei sein.
    For vertical scan, 13048, 13084, 13426, 13825, 13832, and 13848 with symbol rates over 1000.
    If this frequency range is intended for public purposes at all, the reception area should only be Turkey.
  • I think that all I am seeing is transponder noise but they could be real signals, I suppose. During testing, the DVB was receivable at 9-13dB SNR. The LNB is an SMW 12.25-12.75GHz PLL which had an 11.3GHz LO in 2021 but I have modified it to an 11.75GHz LO. The performance is only slightly improved with ~2dB NF, still not great. The notch in the 2021 plot is due to the LO spurious in band. I have about 0.15dB ground noise. The dish is a Prodelin 3122 1.2m offset.
    1.8m PF, Polar mount with SMW Q-PLL type C or R, Precision/Elite feed
  • Today's scan was the same as the one above with just transponder noise and the beacon. Here is a close in plot of the beacon on 13401V with an SNR of ~35dB in 500Hz:
  • I could only check horizontal polarisation but there were 3 signals today including the beacon. I used an SMW Q-PLL type R set to 11.3GHz LO. It's not great with a NF of 3-4dB at 13.6G. 1.8m dish.
    Beacon on 13401H
    Carrier on 13584H
    Frequency hopper. 13416H = 421.4MHz, spectrum inverted. Approx 1 hop/second
    Iv'e got the three up here again as well , usual beacon @ .401 , for me today the frequency hopping is between 13.415 V to 13.417 V. The strong marker at 13584.5 seems to be circular, possibly LHC. [ only using a linear feed onto a Chinese Universal Ext Ku lnbf on a 1.2m CM dish ]
  • Nur 13583 H (linear) konnte ich verifizieren.
    I could only 13583 H (linear) verified.
    Laminas 1800, XMW 13.03-14.03 GHz
