STV 6110 - real band
  • The STV 6110 is a very good Z-converted tuner that is used in many satellite cards, according to the official datasheet it has a frequency range of 950 - 2150 MHz. This allows you to serve the entire standard Ku band.
    However, if you want to explore the 10.4 - 10.5 GHz amateur radio band with a standard LNB, the 950 - 2150 MHz band is not enough. The same is true for the extended Ku band.
    While experimenting with the new option of the IQmonitor Pro program - operation on the third harmonic of the tuner's internal local oscillator - x3, I tried to find out the frequency capabilities of the STV 6110. In addition, I remembered that the tuner's fellow (probably a two-channel analog) STV 6120 successfully operates in the range of 250 - 2500 MHz.
    As a signal source, I used an antenna that was tuned to a 40°E satellite in the Ku band, and then placed a spiral passive antenna (without LNA and LNB) at its focus:
    In order to get around the unreasonable restrictions on the part of the StreamReader, a range with a fake local oscillator Lo = 10GHz was created. Therefore, the true tuning frequency of the tuner is obtained by discarding the left unit on the main spectrum frequency scale and is equal to the frequency of the STV 6110 internal local oscillator, which is signed a little lower in gray font.
    The spectrum was recorded starting from the minimum frequency of the STV 6120 local oscillator - 250 MHz (red curve):
    Then the IQmonitor Pro program was switched to the third harmonic generation mode x3 and the spectrum was re-registered (brown curve)
    This spectrum starts from 750 MHz, which means that below 250 MHz the local oscillator does NOT work, but from 250 MHz it successfully excites the third harmonic.
    It is not difficult to see that the brown curve has a three times larger scale relative to the red one and is stretched three times to the right, starting from a frequency of 750 MHz.
    With this in mind, the curves have the same shape, but different scales and a shifted starting point.
    FeedReports were received on the brown (third harmonic) curve, and the program indicates at what frequency reception can occur on the first (fundamental) or third harmonic
    If the reception occurred at the third harmonic, the width of the transponder body is three times smaller than the width of the peak in the spectrum, because due to scale warping, it is three times as wide.
    If reception occurred at the first harmonic, the width of the transponder body is slightly less than the width of the peak in the spectrum.
    If the reception occurred at the third subharmonic, the width of the transponder body is three times greater than the width of the peak in the spectrum, because due to scale deformation, it is three times narrower. The peak in the spectrum of the fifth subharmonic is, accordingly, five times narrower than that in the first harmonic. This makes it possible to estimate on which harmonic the transponder is registered.
    So, it has been practically proven that the Z-tuner STV 6110 successfully operates in the frequency range of 250 - 2500 MHz :73:
    ____________________________________________________________________________________________________________________________________________________________________________________
    STV 6110 - очень хороший тюнер с Z преобразованием частоты, который используется во многих спутниковых картах, согласно официальному даташиту имеет диапазон частот 950 - 2150 МГц. Это позволяет обслуживать весь стандартный Ku диапазон.
    Однако, если вы хотите со стандартным LNB исследовать радиолюбительский диапазон 10.4 - 10.5 ГГц, диапазона частот 950 - 2150 МГц недостаточно. Тоже справедливо и для расширенного Ku диапазона.
    Экспериментируя с новой опцией программы IQmonitor Pro - работа на третьей гармонике внутреннего гетеродина тюнера - x3, я постарался выяснить частотные возможности STV 6110. Кроме того, я помнил, что собрат тюнера (вероятно, двухканальный аналог) STV 6120 успешно работает в диапазоне 250 - 2500 МГц.
    В качестве источника сигнала использовал антенну, которая в Ku диапазоне настроена на спутник 40°E, а затем в её фокус поместил спиральную пассивную антенну (без LNA и LNB).
    Для того, чтобы обойти необоснованные ограничения со стороны StreamReader`а был создан диапазон с фейковым гетеродином Lo=10GHz. Поэтому истинная частота настройки тюнера получается путём отброса левой единицы на основной шкале частот спектра и равна частоте внутреннего гетеродина STV 6110, которая подписана чуть ниже серым шрифтом.
    Был зарегистрирован спектр, начиная с минимальной частоты гетеродина STV 6120 - 250 МГц (красная кривая).
    Затем программа IQmonitor Pro была переведена в режим генерации третьей гармоники и вновь зарегистрирован спектр ( коричневая кривая)
    Этот спектр начинается с 750 МГц, что означает, что ниже 250 МГц гетеродин НЕ работает, а вот с 250 МГц успешно возбуждает третью гармонику.
    Не трудно видеть, что коричневая кривая относительно красной имеет в три раза больший масштаб и растянута вправо в три раза, начиная с частоты 750 МГц.
    С учётом этого кривые имеют одинаковую форму, но разный масштаб и сдвинутую начальную точку.
    На коричневой (третьей гармоники) кривой были получены FeedReport`ы, причём программа указывает, на какой частоте может происходить приём на первой (основной) или третьей гармонике
    Если приём происходил на первой гармонике, ширина тела транспондера чуть меньше, чем ширина пика на спектре.
    Если приём происходил на третьей гармонике, ширина тела транспондера в три раза меньше, чем ширина пика на спектре, т.к. из-за деформации масштаба он в три раза шире.
    Если приём происходил на третьей субгармонике, ширина тела транспондера в три раза больше, чем ширина пика на спектре, т.к. из-за деформации масштаба он в три раза уже. Пик на спектре пятой субгармонике соответственно в пять раз уже, чем на первой гармонике. Это позволяет оценить, на какой гармонике зарегистрирован транспондер.
    Итак, практически доказано, что Z-тюнер STV 6110 успешно работает в диапазоне частот 250 - 2500 МГц :73:
  • Hello.
    Nice test and confirmation.
    Also, F6DZP, admin of VivaDATV, has successfully tested this tuner from 600mhz to 2600mhz, info.
    DVB Cards collector.
    Hi, if you have a defective dvb card, with CY68013/SAA7160, STV6100/6110/6111/6120, STV0900/0903/0910/0913, please, do not throw away, contact me to add in my collection.
    Thank you. :150:
  • Hello.
    I am familiar with this publication and also believe that the upper limit of the operating range of the microcircuit is equal to half the maximum frequency of the internal generator - 5200/2=2600 MHz. :73:
    But the StreamReader, through which I access the tuner, forcibly limits the upper frequency to 2500 MHz :37:
    Я знаком с этой публикацией и тоже считаю, что верхняя граница рабочего диапазона микросхемы равна половине максимальной частоты внутреннего генератора - 5200/2=2600 МГц.
    Но StreamReader, через который я обращаюсь к тюнеру, принудительно ограничивает верхнюю частоту на уровне 2500 МГц
  • Today I was reviewing the spectrum archive and found unkilled confirmation that the internal local oscillator is capable of delivering intermediate frequencies up to half the frequency of a 5200 MHz voltage-controlled generator
    STV 6120 in RFscan mode worked clearly up to 2600 MHz (see gray scale below the spectrum)
