103.0°E Express AMU3
  • Interesting, I thought N. Korea had just one TV channeI, and also didn't know it moved from Thaicom to Express satellites.
    Tried to translate the names:
    1: Central TV, 9: Ryongnamsan TV, 17: Mansudae TV, 25: Sports TV, 1000: Radio 1, 1100: Radio 2.
    The translate app said "Lazio" but I assume it should be "Radio".
  • First regular TV transmition.
    It's big regional package from North Korea!! :54:
    Thanks for the info. I want to confirm whether this TV package is on Express AMU3 at 103.0E or Express-103 at 96.5E?
    They are not yet listed on any satellite list. Thanks :3:
  • Why not say it? I would have liked Express-103 instead of position 103. Since the package is not listed on the websites, I allowed myself some wishful thinking.:10:
    :76:
    What encoding (CAID) did they use ?
    Hmm, PIDs are different from LyngSat and TSR.
  • Can you upload a recording?
    I think you need to record a Transport Stream. This won't work on a machine running Enigma2. The recording needs to be from a TV card connected to a computer.
    The size dish : jonsa 1.8 meters
    Receiver : Dreambox 800se & Dreambox 820 & VUPlus Uno 4k se & GTMedia V8 FINDER2
  • For e2, you can use record_ts or dvbstream. For me, record_ts gives better results. Null packets from 8191 are not stored.
    I think there is a maximum of 64 PIDs in e2.
    vs card
    PS: Alternatively, you can try a simple analysis
    dvbsnoop 101
    PID: 101 (0x0065)
    Guess table from table id...
    DSM-CC DATAGRAM-decoding....
    Table_ID: 62 (0x3e) [= DSM-CC - private data section // DVB datagram]
    section_syntax_indicator: 1 (0x01)
    private_indicator: 0 (0x00)
    reserved_1: 3 (0x03)
    Section_length: 1460 (0x05b4)
    MACaddrbyte/DevicdID 6: 52 (0x34)
    MACaddrbyte/DeviceID 5: 18 (0x12)
    reserved_2: 3 (0x03)
    payload_scrambling_control: 0 (0x00) [= unscrambled]
    address_scrambling_control: 0 (0x00) [= unscrambled]
    LLC_SNAP_flag: 0 (0x00)
    current_next_indicator: 1 (0x01) [= valid now]
    Section_number: 0 (0x00)
    Last_Section_number: 0 (0x00)
    MACaddrbyte/DeviceID 4: 52 (0x34)
    MACaddrbyte/DeviceID 3: 18 (0x12)
    MACaddrbyte/DeviceID 2: 52 (0x34)
    MACaddrbyte/DeviceID 1: 18 (0x12) => MAC-Address/DeviceID: 12:34:12:34:12:34
    IP_datagram_bytes:
    Version: 4 (0x04)
    IP header length: 5 (0x05)
    Type of service: 0 (0x00)
    Total length: 1447 (0x05a7)
    Identification: 30591 (0x777f)
    Reserved: 0 (0x00)
    DF: 1 (0x01)
    MF: 0 (0x00)
    Fragment offset: 0 (0x0000)
    Time to live: 127 (0x7f)
    Protocol: 17 (0x11) [= UDP]
    Header checksum: 24356 (0x5f24)
    Source address: c0a8507a [= 192.168.80.122]
    Destination address: 0a9603ea [= 10.150.3.234]
    UDP_datagram:
    Source port: 63626 (0xf88a)
    Destination port: 12010 (0x2eea)
    Length: 1427 (0x0593)
    Checksum: 65116 (0xfe5c)
    Data
    0000: 7e ff 08 29 8d cd 05 80 e4 bf 86 10 31 c7 9d bb ~..)........1...
    0010: af 80 61 17 b1 e1 25 38 e7 5d 3e 1c 26 e6 4b c0 ..a...%8.]>.&.K.
    0020: 40 b4 4a 2e 40 f5 a0 d4 c3 33 a3 25 f4 e8 46 8a @.J.@....3.%..F.
    astra --analyze pipe://"dvbsnoop 101 -b"
    Jan 11 23:03:03: INFO: Starting Astra SM 0.2
    Jan 11 23:03:03: INFO: [pipe_input analyze] process started (pid = 19287)
    Jan 11 23:03:04: INFO: Bitrate: 4801 Kbit/s
    Jan 11 23:03:04: ERROR: Scrambled: 0=8
    Jan 11 23:03:05: INFO: Bitrate: 4935 Kbit/s
    Jan 11 23:03:05: ERROR: CC: PID:0=7
    Jan 11 23:03:05: ERROR: Scrambled: 0=7
    Jan 11 23:03:06: INFO: Bitrate: 4529 Kbit/s
    Jan 11 23:03:06: ERROR: CC: PID:0=5 PID:17=2
    Jan 11 23:03:06: ERROR: Scrambled: 0=5 17=1
    Jan 11 23:03:07: INFO: Bitrate: 4951 Kbit/s
    Jan 11 23:03:07: ERROR: CC: PID:0=6
    Jan 11 23:03:07: ERROR: Scrambled: 0=6
    Jan 11 23:03:08: INFO: Bitrate: 4874 Kbit/s
    Jan 11 23:03:08: ERROR: CC: PID:0=6
    Jan 11 23:03:08: ERROR: Scrambled: 0=6
    Jan 11 23:03:09: INFO: Bitrate: 4919 Kbit/s
    Jan 11 23:03:09: ERROR: CC: PID:0=5
    Jan 11 23:03:09: ERROR: Scrambled: 0=5
    Jan 11 23:03:10: INFO: Bitrate: 4967 Kbit/s
    Jan 11 23:03:10: ERROR: CC: PID:0=5
    Jan 11 23:03:10: ERROR: Scrambled: 0=5
    Jan 11 23:03:11: INFO: Bitrate: 4927 Kbit/s
    Jan 11 23:03:11: ERROR: CC: PID:0=2 PID:18=1
    Jan 11 23:03:11: ERROR: Scrambled: 0=3 18=1
    Files
