10.0°E Eutelsat 10B
  • Starting a new a toppic here, thanks to N_Stanislav here. :73:
    3827 L 3867
    3832 L 3867
    4099 L 20950
    4118 L 2167
    4158 L 60940
    There are more on unchanged frequencies, same as on Eutelsat 10A... I will have a deeper look there tomorow, I think... :71:
    /edit: her we go for unchanged GS frequencies:
    3820 R 1200
    3835 R 1333
    3983 L 23330
    4023 L 30000
    PS: complete scans here:
    July 20, 2023 at 5:55 PM
    July 20, 2023 at 6:10 PM
    PS2: I think about 3990 L 25710 in S2X, but not lockable right now.
  • New here:
    3784 L 3087
  • Hi, Qwer,
    Thanks for the C-band spectrum on 10.0E, now that it's from Eutelsat 10B.
    As a novelty, I noticed that the band portion between 3600-3800 MHz is no longer used. Did I understand what I saw from your spectrum?
    And another question would be related to the signal. Have you noticed an improvement in the signal in the band with the frequency shift on the new satellite?
    Thanks :74:
  • As a novelty, I noticed that the band portion between 3600-3800 MHz is no longer used. Did I understand what I saw from your spectrum?
    It's was be made, bcs now band 3500-3800 used for 5G terrestrial networks.
  • Have you noticed an improvement in the signal in the band with the frequency shift on the new satellite?
    As I wrote earlier, in my opinion it´s not easy to say something about improvement in signal from the new satellite, because some (unchanged) frequencies have better signal quality, but also other less...
  • It's was be made, bcs now band 3500-3800 used for 5G terrestrial networks.
    I knew this entirely because I have had C-band interference problems for many years because of these antennas on my block.
    I hope to get a better signal locking in this band, at least on 10.0E.
    Regards :3:
  • Probably new here:
    3861 L 3087
    4099 L 20950
    Changed frequency to:
    4091 L 20950
    3835 R 1333
    4068 R 1333 - locked in manual via TBS 6903X
  • New, I think
    very weak
    3868 L 2400
  • Hi superdish66,
    probably 3868 is from strong circular right signal on 12.0°E? :3:
  • Hi superdish66,
    Yesss, sorry. Thank you qwer
  • Just another scan here after several month.
    New for the list:
    4001 L 6000
    3975 R 4475
    4007 L 18570
    4019 L 19580
    3980 L 21866
    4019 R 3905
    VPid 256/APid 257
    ProviderName: actindia
    3918 L 4500
  • New for the list..
    4013 R 3827
    3970 R 600 - this one could probably be a "mirror" from 3869 R 600 on Blagvest 4 at 12.0°E... :28:
    Dish: 5.00m
    Vu+ Ultimo4k/Zero4k/Zero, Uclan4k, DM Two, h9sSE/h9s/h9 twin, sf8008/sx88/sx88+, Osmini4k, GTX/GT-Combo/GTC/v8UHD/v9prime/v8xs/m7x/, Amiko Alien 1, Mecool K1/K3, Azamerica s2015, Nazabox Xgame, TBS 6904se/5520se/5925/6922se/6903x v2, Openbox X5/S9, AZBOX TITAN twin/Premium+/Elite, Rasp Pi/pi3/pi4, t95 max+, Freesky Triplo X, Orange Pi PC, Coolsat 5000, Dm528s, DM800se, Satlink 6933/6960/6932, Mygica S270, Pixelview PlayTV . Motorized 5m - C band(20ºE - 116.8ºW), Motorized 0,90m
    3851 R 3827
