10.0°E Eutelsat 10B
  • Today many channel moving from old 10A to 10B in Ku-band. Can someone to check? :51:
    African channels moved from band 10700-10950 to 12500-12750V. For me - no any signs.
  • Some frequencies have been tested, some have been kept, and others are in testing.
    The ORTC program has a copy in the upper band on 12642 V,2060,3/4.
    The other African and Portuguese programs have been deactivated.
  • It's strange, what beam coverage from 10B. At my location another spectrum on 12500-12750, just see
  • Here's what the upper band looks like. The signal on the older frequencies(12526 V and 12532 V) is weaker.
    12590 H,16148,3/4,32apsk is a new one, activated today.
  • Hier mal, was am Standort mit 125 cm geht.
    Das horizontale Spektrum im 12 GHz Bereich ist total unbrauchbar, was ist damit los?
    Bastelt man da bei Eutelsat gerade rum?
    Ich bin ganz zufrieden. 2 mal ORTC.
    Wenn Euch an meinen Spektren irgendetwas auffällt, was auf einen Fehler an meiner Anlage hinweisen könnte, dann würde ich mich über einen HInweis freuen.
  • I would make one observation, but it is not obligatory: I would uncheck the "Mark width" function in Crazyscan to see better the parameters, especially when the muxes are close. (See picture) :3:
  • 11222 V DVB-S2/QPSK 30000 5/6
    11346 H DVB-S/QPSK 27500 3/4
    12642 V DVB-S2/QPSK 2061 3/4
  • I see that 11222 I receive it with 2.5 dB of mer less than satellite 10 A
    Lodi sud
    laminas 180
    tbs 6983-6522-6903X
    rover tab 900 plus
    proform KTI h 180
  • Although it cannot be known (yet) what content these carriers will have, according to the parameters, it seems to be allocated to Radio Maria. Probably they are doing internal tests; who knows? :25:
  • Hello, I am Andreasgrdx from Athens, Greece.
    These are pictures with official footprints (C , KU , 2 KU-HTS) from Thales Alenia Space video about the new satellite Eutelsat 10B (10.0° East) without dBW .
    EUTELSAT 10B, a new all-electric satellite for inflight and maritime connectivity services
    External Content youtu.be
    C-band
    KU-band
    2 KU-HTS
    85 cm ,100 cm , 120 cm KU 85.2° E - 45.0° West
    Athens , Greece
  • 10733 H,33000,2/3,16APSK-Eumetcast, probably. ( dreamsat on the UK forum)
  • In 2022, they planned to use 10780 H
    they changed in July 2023
  • Hallo,
    aktueller Scan mit der 1,8m.
    Die 12736 V 4000 wird immer mit eingelesen, obwohl das Signal deutlich
    unter der Lockschwelle ist. (Parameter sind nicht korrekt)...
    Die 10731 H hier sehr stark. :3:
  • Hier das gleiche.
    Ps: Zap Viva ist Mis 171, nicht vergessen einzutragen Kathrein018
    Suedschwede Setup
    > 2x AX HD51 4k
    > 2x SF 8008 Twin
    > 1x SF 8008 Mini
    > 1x SX 88 V2 Dual
    > 1x Edision Os Mio 4k
    > 1x OpenboxSX6
  • Danke für den Hinweis!
    Hab ich schon korrekt drin...
    Ist schon eine Hausnummer. Mit 2,7m 11,8dB, ca. 0,8dB Reserve dann ist das Bild wech. :35:
    Bei mir eben kein Lock und er liest den Tp. mit ein. :426:
    Kathrein CAS 018 KU-Band 80°Ost - 45°West - Invacom SNF-031 / Polarmount mit ASC1
    Kathrein CAS23 C/KU - Invacom SNF-031
    SF8008, Goldmaster SR-525HD, SR-200HD EXTREME 4K, TBS 5927 USB
  • Just my current scan on 2.2m.
    12736 V 4000 9/10 DVB-S2 8PSK - not lockable - about 5dB under LM
    PS: I can confirm unlockable QPSK signal at about 12673 H, but can´t confirm SR 255.
    Indeed, we have no device or application capable of reading the signal at 12672-12678 H to be sure that it is a valid transmission. Only IQmonitor, when searching manually, discovers/generates some parameters, but all muxes have the same signal level.
    There is definitely some activity on these transponders but probably (who knows) they are operator tests(?).
  • 10770 H,22960,3/4-Service name: AFP2 EU.
    Copy of 11345 H,27500,3/4 of the same Eutelsat service on 10.0E.
