10.0°E Eutelsat 10B
  • 12688 V,9090,1/2,S2,0.10-Data, new
    Transponder PID-Scan...
    PID found: 0 (0x0000) [SECTION: Program Association Table (PAT)]
    PID found: 16 (0x0010) [SECTION: Network Information Table (NIT) - actual network]
    PID found: 17 (0x0011) [SECTION: Service Description Table (SDT) - actual transport stream]
    PID found: 36 (0x0024) [SECTION: Program Map Table (PMT)]
    PID found: 37 (0x0025) [SECTION: Program Map Table (PMT)]
    PID found: 38 (0x0026) [SECTION: Network Information Table (NIT) - other network]
    PID found: 1347 (0x0543) [SECTION: DSM-CC - private data section // DVB datagram]
    PID found: 2098 (0x0832) [SECTION: ATSC reserved]
    PID found: 2099 (0x0833) [SECTION: ATSC reserved]
    PID found: 5632 (0x1600) [unknown]
  • FYI: I duplicate this thread in this new toppic, because:
    12688 V,9090,1/2,S2
    ...seems like transmitting also in S2X... :83:
  • You're right; I figured it out with S2X when I discovered it. But because I only found RollOff 0.10 or 0.05, and dummy, I only posted it with dvb-s2.
    Anyway, that's the only way to lock it. Maybe with a stronger signal, other s2x parameters can be found. :3:
    Indeed, 12688 V,9090, 32/45 in S2X/16APSK, RollOff:0.10 :3:
  • Indeed, 12688 V,9090, 32/45 in S2X/16APSK, RollOff:0.10 :3:
    12688 V,10037,23/36,S2X/16APSK-Data, new symbol rate
