10.0°E Eutelsat 10B
  • 12688 V,9090,1/2,S2,0.10-Data, new
    Transponder PID-Scan...
    PID found: 0 (0x0000) [SECTION: Program Association Table (PAT)]
    PID found: 16 (0x0010) [SECTION: Network Information Table (NIT) - actual network]
    PID found: 17 (0x0011) [SECTION: Service Description Table (SDT) - actual transport stream]
    PID found: 36 (0x0024) [SECTION: Program Map Table (PMT)]
    PID found: 37 (0x0025) [SECTION: Program Map Table (PMT)]
    PID found: 38 (0x0026) [SECTION: Network Information Table (NIT) - other network]
    PID found: 1347 (0x0543) [SECTION: DSM-CC - private data section // DVB datagram]
    PID found: 2098 (0x0832) [SECTION: ATSC reserved]
    PID found: 2099 (0x0833) [SECTION: ATSC reserved]
    PID found: 5632 (0x1600) [unknown]
  • Just starting a new toppic here...
    10822 V 30112
    11381 H 36800
    11484 H 16188 - very low signal
    12527 V 2333
    12533 V 1145
    12597 V 1000
  • One more:
    11538 V 57130 - I think this one uses also S2X
    PS: There is another one on 11560 H, but I do not know SR...?
    X-band: 17.8°W-60.2°E KATHREIN CAS 120 (1,2m) - standby
  • 11408 V,25540,1/4, S2,Multi 1->254-GS,new,
    11408 H,25540,1/4, S2,Multi 1->254-GS,new,
  • 10920 H & 10911 V 63900 1/4
    I don't think about a coincidence with these reports @61°W ...:Amazonas 6
    same SR, same MIS
    same SR, same MIS
    I couldn't find the two muxes 10920 H and 10911 V at 10.0E. Are they still active in your area?
  • Yes
  • Thanks for the spectrum on Eutel 10B. :3:
    Strangely, on my analyzer, there is no signal at all on the two muxes. I wonder if there is such a big difference between the Eutelsat 10B spots?
    Or are they local tests, which got you thinking when you compared them with the two muxes on Amazonas 6?
    I scanned the satellite again and nothing showed up on my spectrum. :25:
    added: I forgot to ask you, with which antenna did you get this signal?
  • 1.80m for all my KU band scans as usually
    SPOT beams I think
    check your scan and mine:
  • Thanks again, Feedsat.
    I think it is clear to me now that the difference in signal is due to both the different sizes of our antennas, and also to the areas where we receive this signal.
    Now another mux appears at 11441 H on your spectrum, but very weak even on the 1.80m antenna. I'm not even looking for this one.
    It seems that on this Eutelsat both polarities are used on the same frequency, like the two you posted. If on others, 11375 HV, 11408 HV, and 11262 HV, the signal is at the same level on both polarities, on the latter, it is different in strength. On the Horizontal pole, it is stronger than on the Vertical.
    Signal differences between different areas of the continent seem to have dissatisfied many users when Eutelsat became operational, starting with Eumetsat customers and others.
    In fact, the message is clear: Gone are the days when we could receive satellites even with relatively small antennas(especially true for me). The moral for enthusiasts was and still is, as it was in the past, use only large antennas, buy the latest signal processing devices, and update apps.
    Best regards :74:
  • 11003 H 9522
  • Here are my results on 2,2m in range 10.70 to 11.50 GHz from my place. Just compared to Feedsat scans above in this toppic... :72:
    10822 V 30112 - ecncrypted VPID 2048/APID 8001 - probably "my" beam :26. , according above scan from Feedsat
    10827 H 36811 - lockable here too on low signal -> Feedsat spot beam :26.
    10911 V 63900 - probably "my" beam, according above scan from Feedsat
    10920 H 63900 - lockable here too on low signal -> Feedsat spot beam
    11002 H 9524 - lockable here too on low signal -> Feedsat spot beam
    11381 H 36800 - ecncrypted VPID 2048/APID 8001 - strong signal...probably "my" beam...?
    11382 V 36821 - low signal ... not really "my" beam
    11439 H 63900 - strong signal...probably "my" beam...?
    11440 V 63900 - low signal ... not really "my" beam
    PS: posted GS frequencies in scans from satesco are not visible in our (Feedsat and mine) spectrum:
    11408 H and V with SR 25540
    So there is another spot beam for satesco... :26.
  • 11382 V 36821 - low signal ... not really "my" beam
    ...possible to show NIT here
  • Here my upper band - nothing new lockable, still there:
    12527 V 2333
    12533 V 1145
    12597 V 1000
  • 11381 H 36800 - ecncrypted VPID 2048/APID 8001 - strong signal...probably "my" beam...?
    If 11381 H is a spot for Western Europe, then 11376 H is a spot for Eastern Europe
    broadcasts in several modes (modcode?)
    an encoded CNN is available in one of them
    likewise 11382 V for Western Europe and 11377 V for Eastern Europe (but weaker than 11376 H)
    due to the weaker signal, the third mode is difficult to pick up
    Edited 2 times, last by EnoSat (September 18, 2023 at 2:42 AM).
  • 10E - maybe -
    10733 V/H - Wide beam
    10770 V/H - Wide beam
    10825 V/H - West Europe Spot
    10915 V/H - West Europe Spot
    11200-11350 V/H - Wide beam
    11330 H - East Europe Spot
    11380 V/H - West Europe and Central Europe Spot (thx. Stanislav)
    11408 V/H - Central Europe Spot (thx. Stanislav)
    11440 V/H - North Europe Spot ?
    11540 V/H - West Europe Spot ?
    12670 V - East Europe Spot
    Edited 2 times, last by EnoSat: thx. Stanislav (September 19, 2023 at 10:11 AM).
  • Was ich im unteren Bereich empfangen kann, vielleicht sind ein paar Spotbeams drin, ich habe null Ahnung, woher der 11045 H kommt.
    here's what I get in the low band, maybe a few spot-beams, I have no idea where the 11045 H comes from.
  • Hier sind meine Scan Ergebnisse mit 125 cm am Standort.
    Radio Maria ist weit weit weg von einer Empfangschance und ob der Empfang bei ZAP Viva Internacional klappen würde?.
    Ein dB Wert ist da, aber alle anderen Parameter wie SR und FEC werden ja nicht eingelesen.
