10.0°E Eutelsat 10B
  • wenn man bei Satbeam alle Beams sich anguckt , es ist wirklich sehr sehr schwer zu finden mit welchem Beam man zu tun hat. :25:
    When you look at all the beams on Satbeam, it is really very hard to find which beam you are dealing with. :25:
  • it seems that the spot numbers were also mentioned in the title (for example, spot 12 is stronger for me than 13, which also corresponds to its direction)
    11002.34 H - M_Ku_RMB_E10B_S031_N01_1076
    11375.58 H - BEAM_E10B-H12_X01_0512
    11376.75 V - BEAM_E10B-H13_X01_0513
    11382.03 V - BEAM_E10B-H09_X01_0509
    11471.41 H - M_Ku_RMB_E10A_EU_N01_1050
    11595.91 V - Eutelsat Advance E10A EMEA
    12672.85 V - BEAM_E10B_G106_S01_0606
    12688.67 V - M_Ku_RMB_E10B_S106_N01_1061
    Durch den Vergleich unserer 120er Werte könnte man da vielleicht ein wenig Klarheit schaffen?
    PC Card: TBS 5925. Aktuell genutzte Receiver: Amiko Viper 4K, OB S3 Mini II, Dr HD D15, OB SX6.
  • Durch den Vergleich unserer 120er Werte könnte man da vielleicht ein wenig Klarheit schaffen?
    Hier was ich mit der 1200 Laminas bekommen kann
    Here what I can get with the 1200 Laminas
  • In my area, the signal on Eutelsat 10.0B spots looks like this, on the spectrum, than in Western Europe, a signal is locked with Crazyscan(6983 card) and neumoDVB(6903x card).
    I thought these days that 12506 H, Radio Maria, had left, especially as I noticed that many users couldn't find it, but I see now that it is active.
  • I thought these days that 12506 H, Radio Maria, had left, especially as I noticed that many users couldn't find it, but I see now that it is active.
    Ja Radio Maria ( Program 1) ist aktiv , aber ziemlich schwer zu bekommen , daneben sind andere Signal , die vielleicht stören können
    Yes Radio Maria (Program 1) is active, but quite difficult to get, next to it are other signals that may interfere.
  • Was ist so besonders an ZAP Viva Internacional auf 12736 V, ausser Multistream und wie viel dB braucht es zum
    Empfang des Programms? Warum werden trotz gut 5 dB keine weiteren Parameter wie SR oder FEC eingelesen?
  • Vielleicht ein Spotbeam?
    Auf dem Wide Beam sollte hier doch ein stärkeres Signal ankommen?
    Maybe a spot beam?
    Should the signal on the wide beam not be much stronger?
    In itself, Zap Viva is nothing special, but it becomes such, as all muxes that cannot be locked are special because they are hard to catch from the location we are in. For example, Middle East or Central Asia spots are special for Europeans, and vice versa.
    Let's not forget that we are on a dxes forum. That's why everything posted here is special. :3:
  • 11037 V 56895
  • Hi,
    I cannot lock from my place 11037 V 56895, but I can "see" an existing signal via manual, using TBS 6903.... :26.
    Already in Feedsat scan above:
    10994 V 9524
    New for me:
    11041 H 36808 - low signal at my place
    No changes in upper band.
