Psyche (Destination 16 Psyche)
  • From JPL Horizons:
    Code
    Revised: Oct 14, 2023            Psyche Spacecraft / Sun                  -255
                                    https://www.nasa.gov/psyche
                                      https://psyche.asu.edu/
      Psyche is a NASA Discovery-class mission to map the surface and characterize
      the composition of '16 Psyche', an elongated 280-km diameter metal-rich
      asteroid located in the main asteroid belt between Mars and Jupiter. This
      is the first mission to a metal-rich asteroid.
    Unfortunately I missed it when it was close enough to see the modulation. These plots were when it was about 1.41Mkm from Earth.
    1.2M dish, 1dB NF LNA, 9GHz LO (waterfall plot)
