• Oops, N_Stanislav was reporting a few minutes earlier... :3:
    11727 H 27500 3/4 DVB-S2 8PSK, MBC HD mux
    11766 H 27500 3/4 DVB-S2 8PSK, MBC HD mux
    Currently no signal from my place with 2.2m on these ones.
    :49: PS:
    LyngSat listed 11606 H 27500 3/4 DVB-S, Oman TV package on Badr-8 (FSS MENA) - I can´t confirm from my place because I get 11604 H 27500 3/4 DVB-S, Aljazeera package from position 25.5°E... :28:
  • 11472V still there, 7.0db currently. And I believe it's on Badr8
    According LyngSat it´s from Badr-8. :69:
    I moved these reports about 11472 V to Badr-8 toppic now...in hope it´s okay...
  • Two new tp are active today from Badr8. For my place it's easy to identify.
    But this only data streams
    12553H DVBS2/32APSK 12300 3/4
    12694H DVBS2 2000
    and also something appeared at 12606V, but no lockable
  • Not my catch, AhmadIraqi on satellites.co.uk forum right now:
    11472 V 4165 8/9 DVB-S2 QPSK
    11472 V is lockable again today from place.
  • Quite good/stable signal this morning on this one...whatever satellite name for this one is...
    11472 V 4165 8/9 DVB-S2 QPSK - still "infodia" on VPid 256
  • Was ich heute früh bekomme ( Schnee auf der Antenne)
    What I get this morning (snow on the antenna)
    Wie ist der Empfang mit Deiner 1,2 m Antenne?
    How ist the reception with your 1.2 m antenna?
  • I´m happy, range 12.3 to 12.5 GHz is also back here at my place. :91:
    PS: 11472 V currently on the limit...
  • Mir stellt sich an Hand des aktuellen Scans die Frage, ob ein kurzfristiges Aufstellen einer 150er Gibertini für 26° Ost an meinem Standort gravierende Änderungen mit sich bringen würde gegenüber dem aktuellen Empfang mit 125 cm, speziell was den Badr 8 Empfang zwischen 12300 und 12500 MHz und den NWA Beam von Badr 7 zwischen10900 und11030 MHz anbelangt.
    Based on the current scan, I am wondering whether setting up a 150 Gibertini for 26° East at my location at short notice would bring about serious changes compared to the current reception at 125 cm, especially regarding the badr 8 reception between 12300 and 12500 MHz and the NWA beam from badr 7 between 10900 and 11030 MHz.
  • Ein Nachtrag: Aktueller Scan mit EBS:
    Wurde der Transponder 11919 H auf Badr 4 oder den FSS EMENA Beam von Badr 8 umgeschaltet?
    Der war hier seit der Umlegung weg von Badr 4 vor ein paar Jahren nicht mehr zu empfangen.
    Aktuell 9.8 dB mit dem CT 4800, 6 Programme werden gefunden.
    An addendum: Current scan with EBS:
    Was the transponder 11919 H switched to Badr 4 or the FSS EMENA beam from Badr 8?
    It hasn't been available here since the transfer from Badr 4 a few years ago.
    Actually 9.8 dB with the CT 4100, 6 programs were found.
  • Was the transponder 11919 H switched to Badr 4 or the FSS EMENA beam from Badr 8?
    According william-1 on satellites.co.uk forum, 11919 H now on Badr-8. (My signal increased today about 4-5dB) :69:
