30.5°E Arabsat-5A <Pan-Arab>
  • Just a New Years Day scan form that beam. Good reception from my place...
  • Normaler Weise erreichen die Transponder auf dem Pan-Arab Beam hier am Standort mit 125 cm immer gerade so das Limmit, wenn sie denn mal empfangen werden können. Um so größer meine Überraschung heute auf 12541 V 1660 5/6. Mit der Openbox S3 Mini II bringt es der Transponder auf stolze 9.5 dB. Empfang ohne Aussetzer.
    Normally, the transponders on the Pan-Arab beam are always at their limit at 125 cm on my location, if they can be received. My surprise today on 12541 V 1660 5/6 is all the greater. With the Openbox S3 Mini II the transponder reaches an impressive 9.5 dB. Reception without dropouts.
  • Just for LyngSat stats... Tele Liban (Lebanon) is on 12541 V 1660 5/6 (again)...
  • 12731 V,2590,3/4-Eritrea TV,(12731 V is on Qwer's spectrum). :3:
  • Just my current scasn from that beam and position...
    /edit: 12530 V 1600 5/6 lockable in manual (too low signal for screenshot))
  • My difficult situation with actual non completed setup
  • Finally locked from here this evening, smooth vision
    12530 V 1600 DVB-S2 8PSK 5/6
    .. and,
    12731 V 2800 DVB-S2 8PSK 3/4 - ERI TV Feed, never locked before
  • Just my current scan.
  • Here is the signal and transponders found in the upper band during this outage period in my area.:3:
  • Current BS from my place in Highest Band V pol. 4,2Mt
    12524 V not rechable and not intercepted
  • Just my november ´25 scan.
  • 12530 V 1600 DVB-S2 8PSK 5/6
    Gone on the limit from my place. Not good beam situation from here for 5A
  • Hi superdish66
    my situation on this beam is a bit better here more north from your QTH...
    PS: Merged your report above in DX toppic.
    PS: Feed on 12525 V is not lockable for me (found in re-scan).
  • Hi superdish66
    About 1.5dB weaker from here :3:
  • Just my first scan in year 2026 from that position and beam...
