78.5°E Thaicom 8 <Steerable>
  • One lockable right now on strong signal:
    11153 H 2500 3/4 DVB-S2 8PSK, ID: ALKAFEEL
    It's regular transmission here, they moved from 70E, Tx for found they!
  • 11153 H 2500 3/4 DVB-S2 8PSK, ID: ALKAFEEL
    Just my todays signal.
  • In this cold, frosty period, the signal on Thaicom 8 on 11153 H,2500,3/4,8PSK is strong and favorable for smaller antennas.
    It's worth a try. :3:
    Quite good signal here on 11153 H ... but all feeds are far away from lock...
  • Currently, at 78.5E. :3:
  • New IRIB Package (steerable beam) favorable reception in Europe
    11010 H 30000 3/4
    11050 H 30000 2/3
    Laminas AS-1500 + Jaeger SMR 1224 HH Mount (80E - 45W)
    Inverto Black Ultra LNB
    U2C Denys H.265
    PC card TBS 5922
    Edited once, last by Cybertomanek (April 14, 2025 at 7:43 AM).
  • Big thanks Cybertomanek :76:
    Fluctuating signal here on both, but lockable on the limit (2.2m)...
    11010 H 30000 3/4 DVB-S2 8PSK - locked in manual
    11050 H 30000 2/3 DVB-S2 8PSK
  • And in my area, IRIB appeared with the two packages, and still with a surprisingly good signal. :3:
    11009 H,30000,3/4,8PSK,H.264-IRIB pack,
    11049 h,30000,2/3,8PSK,HEVC-IRIB, pack.
  • I thought it would be sorted out soon:25:
    My tr. 11010 H 30000 went out a moment ago
    The second one is still working for me 11050 H 30000
    Maybe one of you can check?
  • But they're trying to figure it out
    The tr.11010 H 30000 was turned on again a moment ago and it was unavailable:26.
    2x T90 + diseq 1\16
    Channel Master 180cm // 80e-58w // 2xCband / LR / VH / Ku-band ( Dismantled)
    Channel Master 2,4m (Poland) Kołnierz podwójny Inverto biały ultra/2xNEW C-band 5G :18:
    Antena Laminas 2710/3015 / 2xCband LR/ VH / Ku-band ( Dismantled)
  • Indeed, I confirm that both recently activated transponders are there atm. :3:
  • Just my early summer 2025 scan... still very fluactuating signal... lock-nolock... 11153 H 2500 3/4 in manual later...
