13.25°E H2Sat (Heinrich Hertz)
  • <Edit> Was at 0.5E, moved to 13.25E November 2024
    Has anyone seen anything from this satellite, apart from its Ku beacon?
    ITU had the following bands listed:
    2283.5-2288.5MHz (TT&C)
    10950-11700MHz
    19.7-20.2GHz
    20.2-21.2GHz
  • Hi s-band
    My circular scan shows a peak at 20200 on 1.8m.
  • Thanks, qwer, I had another look on Ku and can just see the a BPSK that flips in the demod creating an X.
    I also noticed that there's a carrier on 10951MHz which appears to be circular polarised.
  • Just a try here on 2.2m... on 10951 and 10953...
    I can see a "butterfly" (joke)
  • Wenn man sich Wikipedia ansieht, könnte das K-band erfolgversprechender sein, als das Ku-Band.
    If you look at Wikipedia, the K-band might be more promising than the Ku-band.
  • I found this pre-launch document:
    Heinrich Hertz Mission - eoPortal
    It looks like you are correct femi
    • 7 channels with 36 MHz bandwidth each at Ka-band (= appr. 7 x 50 Mbit/s = 350 Mbit/s)
    • 1 channel with up to 450 MHz bandwidth at Ka-band (= appr. 1 x 625 Mbit/s)
    • [1 ISL (Intersatellite Link) with 36 MHz bandwidth at Ka-band (= appr. 1 x 50 Mbit/s)]
    • 1 channel with 45 MHz bandwidth at Ku-band (= appr. 1 x 62 Mbit/s)
    The coverage map shows a different orbital position but 2 of the beams are very tight on north and south Germany. There probably will not be anything de-codable.
  • Now in circular range from Ka Band B... peak is probably on: 20198
  • s-band December 4, 2024 at 11:09 AM
    Changed the title of the thread from “0.5°E H2Sat (Heinrich Hertz)” to “13.25°E H2Sat (Heinrich Hertz)”.
  • Thanks to hvdh for the information, H2Sat has moved to 13.25E. I can't see anything from it on Ku now as it is too close to 13E and its beacon frequency has a DVB signal on it.
