38.2°E Paksat-MM1R
  • According hvdh Paksat-MM1R arrived position 38.2°E. :76:
    According Marcus_21 on satellites.co.uk forum (here as Capitan_Uncino), two telemetry frequencies 4194,00 V and 3946,50 H appeared. :73:
    I can confirm these ones here.
  • ...I will check it soon... just in circular "mode" atm... :69:
  • Unfortunately, my antenna is too small to lock PakSat. I locked only 4069 R,1000,3/4,32APSK. :3:
  • May be this one at least now from MM1R, bcs old Paksat 1R don't receivable here (gives only 4-5dB)
    For example this one from old 1R, only 3dB.
  • Here are my results from posotion 38.2°E...
    Signal increases very strong on 3848 H 1085... so I can confirm what N_Stanislav reported before.
    Also signal check on 3835 H 6500...?
    PS: 3886 is from 40.0°E
  • I can see the the beacons using a RHCP feed on a 1.8m dish but nothing lockable (RH only)
    1.8m PF, Polar mount with SMW Q-PLL type C or R, Precision/Elite feed
