30.0°W XTAR-Lant (TV Broadcast)
  • These 2 were first found by dreamsat on SatsUK. There must be more on the streams but I can only see the 2 channels with 640 x 360 resolution. It took a while to get full pictures from 7702MHz and I did not manage to get any complete frames from 7649MHz. There were bursts of audio form each. I was using a 1.8m PF dish.
  • Great, @ s-band. Maybe your post will encourage me to try the X-band.
    I wonder where I can find such an LNB that doesn't cost much, if possible.
    I also don't know if a 1.50 antenna can cope with X-band reception.:3:
  • I question if it's worth spending time on X milsat but can't help it! Originally, I did it as a stepping stone to DSN. There's a lot to be found in the Earth observation part 7.75-8.4GHz so it's worth getting an LNB that will cover it all if possible. I've never tried them but I think this company https://roks-tv.com/lnb-xpxx-v1 has much better pricing than SMW/Norsat etc. I believe that they will do custom versions as well.
    1.5m is fine for milsat and Earth obs. I was using a 1.2m before this 1.8m.
  • satesco:
    Was roks-tv betrifft, kann ich nur bestätigen.
    Bei Norsat reden wir von etwa 1500 € pro X-band Typ, inkl. Steuern.
    Viel schwieriger finde ich das Feed-Problem.
    Ich orderte einst ein conical und ein pyramidal Feed für das X-band aus Indien.
    Da sie sehr lang sind, müßte man sie außerhalb der üblichen Einspannung befestigen.
    Anhand der Dimensionen von C- und Ku-band habe ich dann ein Feed aus Vollmaterial gedreht.
    Auf Grund diverser probleme mit den Anlagen ist das X-Band vorerst auf standby.
    As far as roks-tv is concerned, I can only confirm.
    At Norsat we are talking about €1500 per X-band type, incl.VAT.
    I find the feed problem much more difficult.
    I once ordered a conical and a pyramidal feed for the X-band from India.
    Since they are very long, they would have to be attached outside of the usual clamping.
    I then shot a feed from solid material based on the dimensions of C- and Ku-band.
    Due to various problems with the systems, the X-Band is on standby for the time being.
  • TS Reader outputs and a good picture capture from 7702MHz:
  • Just my try on:
    7648 L 10700
    7702 L 20000
    scan click!
  • 7702 L 20000
    ...according TV-logos, it looks like M+ (Movistarplus) package from Spain (same as on 29.0°E XTAR-Eur) ... VPid 102 and APids 102/1002/5006
    M+ Cine, M+ Series, M+ Vamos, M+ Originales, Canal 24 horas,...
  • Quite good screenshots today on Canal 24 horas (7702 L 20000) on ID Service01 and VPID 101.
  • Quite good snapshot of service "LaLiga TV BAR" on stream 7702 L 20000 today...
  • Just my signal check on 7702 L 20000 today...
    ...same situation today...
  • Today I can analyze VPid 121 on 7648 L 10700...
  • :49:FYI:
    7702 L 20000 has left since a couple of days...
    Two unlocked frequencies appeared - but both very far away from lock....
    7689 L 46745
    7725 L 18700
  • 7702 L 20000 has left since a couple of days...
    ...hey, 7702 L 20000 is back, Ten Years After :75:, oops 10 days after ... on weak signal...
    /edit: ...weak signal on 7702 L 20000, because 7689 L 46745 is still active... :77:
  • ...hey, 7702 L 20000 is back
    ...no changes here... too bad situation... very low data rate and no VPids are visible in stream...
  • ..hey, 7702 L 20000 is back, Ten Years After :75: , oops 10 days after ... on weak signal...
    ... disturbing 7689 L has left... so good signal for 7002 L again...
    /edit 10.04.25: used Modcode QPSK 4/5
  • ...and active again today...
    7429 L 1000
    /edit: and some Logos of the day... ("eesa" is from Canal 24 Horas, I think)
  • Some pics of the day on 7702 L 20000...
  • There are two ID´s (as reported in earlier pics already): Service01 and _Service 1 on known content at 7702 L 20000 Modcode: QPSK 4/5...
    M+ Cine, M+ Series, M+ Vamos, M+ Originales, M+ Estrennos, M+ Hits , LaLiga TV BAR, DAZN, Canal 24 horas (Spain)
    Pic of the day...
    Uff, they are still on there... (no clear video)
    /edit: Also VMA Stream Reader and VMA Transport Stream Analyzer can open the VPid 101
