These 2 were first found by dreamsat on SatsUK. There must be more on the streams but I can only see the 2 channels with 640 x 360 resolution. It took a while to get full pictures from 7702MHz and I did not manage to get any complete frames from 7649MHz. There were bursts of audio form each. I was using a 1.8m PF dish.
30.0°W XTAR-Lant (TV Broadcast)
Great, @ s-band. Maybe your post will encourage me to try the X-band.
I wonder where I can find such an LNB that doesn't cost much, if possible.I also don't know if a 1.50 antenna can cope with X-band reception.
I question if it's worth spending time on X milsat but can't help it! Originally, I did it as a stepping stone to DSN. There's a lot to be found in the Earth observation part 7.75-8.4GHz so it's worth getting an LNB that will cover it all if possible. I've never tried them but I think this company https://roks-tv.com/lnb-xpxx-v1 has much better pricing than SMW/Norsat etc. I believe that they will do custom versions as well.
1.5m is fine for milsat and Earth obs. I was using a 1.2m before this 1.8m.
Was roks-tv betrifft, kann ich nur bestätigen.
Bei Norsat reden wir von etwa 1500 € pro X-band Typ, inkl. Steuern.Viel schwieriger finde ich das Feed-Problem.
Ich orderte einst ein conical und ein pyramidal Feed für das X-band aus Indien.
Da sie sehr lang sind, müßte man sie außerhalb der üblichen Einspannung befestigen.
Anhand der Dimensionen von C- und Ku-band habe ich dann ein Feed aus Vollmaterial gedreht.Auf Grund diverser probleme mit den Anlagen ist das X-Band vorerst auf standby.
As far as roks-tv is concerned, I can only confirm.
At Norsat we are talking about €1500 per X-band type, incl.VAT.I find the feed problem much more difficult.
I once ordered a conical and a pyramidal feed for the X-band from India.
Since they are very long, they would have to be attached outside of the usual clamping.
I then shot a feed from solid material based on the dimensions of C- and Ku-band.Due to various problems with the systems, the X-Band is on standby for the time being.
Just my try on:
7648 L 10700
7702 L 20000
scan click! -
7702 L 20000
...according TV-logos, it looks like M+ (Movistarplus) package from Spain (same as on 29.0°E XTAR-Eur) ... VPid 102 and APids 102/1002/5006
M+ Cine, M+ Series, M+ Vamos, M+ Originales, Canal 24 horas,... -
Quite good screenshots today on Canal 24 horas (7702 L 20000) on ID Service01 and VPID 101.
...same situation today...
...hey, 7702 L 20000 is back
...no changes here... too bad situation... very low data rate and no VPids are visible in stream...
Some pics of the day on 7702 L 20000...
There are two ID´s (as reported in earlier pics already): Service01 and _Service 1 on known content at 7702 L 20000 Modcode: QPSK 4/5...
M+ Cine, M+ Series, M+ Vamos, M+ Originales, M+ Estrennos, M+ Hits , LaLiga TV BAR, DAZN, Canal 24 horas (Spain)
Uff, they are still on there... (no clear video)
/edit: Also VMA Stream Reader and VMA Transport Stream Analyzer can open the VPid 101
