Some changes:
3784 V 2900 5/6 DVB-S2 QPSK, Sindh News, Sindh TV
3838 V 4792 5/6 DVB-S2 8PSK, TMN mux (EXP Music with TC at this time)
Some changes:
3963 V 2356 3/4 DVB-S2 8PSK, 7 News HD, lockable again - was not possible in yesterdays scan.
Two no-locks:
3754 V 7500 3/4 (0.7dB under LM) /edit: lockable at 8 p.m.
3832 V 2600 3/5 (4dB under LM) ->weakest signal
Strongest signal from this position, I think: 3760 H 1004 1/2 (about 9dB over LM).
3788 H 3200 2/3 - under lock this morning...
Arrgh! I forgot to check 3798 H 3200 2/3 in last horizontal scan above.
/edit:
10 a.m.: 3788 H - lockable, signal increased (+4.7dB)
... and now on 3800 H 3200 2/3 DVb-S2 8PSK, PNN News - 3788 H not lockable - QPKS constellation...
So probably PNN News uses these frequencies "temporary": 3788 H, 3798H and 3800 H. Still active on 38.2°E 3914 V.
/edit:
26.04.2021 (11.35 a.m.): 3788 H active - without content at this time...
26.04.2021 (2.15 p.m.): 3788 H - PNN News active
Just my complete scan (not all in one BS). some changes...
3813 V 16850 3/5 DVB-S2 8PSK, Geo TV package - aleady reported by Ramiz on FlySat 04.06.2021
3952 V 2013 3/4 DVB-S2 QPSK - "big content" on enabled PIDs (on such a small SR )
Was ich mit 1,80m empfangen kann ,
von 4000 bis 4200 leider von 3700 bis 4000 stört der Express AM7 sehr viel .
wenn die dB in blau sind , sofort gelockt ,
wenn schwarz Manuel blindscan.
What I can receive at 1.80m ,
from 4000 to 4200 unfortunately from 3700 to 4000 the Express AM7 interferes a lot .
if the dB are in blue , immediately locked ,
if black Manuel blindscan.
Что я могу получить на 1,80 м ,
от 4000 до 4200, к сожалению, от 3700 до 4000 Express AM7 сильно мешает.
если dB имеет синий цвет, немедленно блокируется,
если черный Мануэль слепит.
Hi Stephan.
What LNB do you use for the C band? The pictures show Inverto Black Ultra. Is he on the Ku band, or am I wrong?
Well thank you.
Hi
You are absolutely right. Peon.
I forget to change the LNB on the board, every time I switch to C-band or KA-band
In C band I use a Titanium + AVcomm
Hi,
I'm probably bothering you, but can you give more details, or a photo?
I also use Titanium C1W PLL, etc.
I don't know what AVcomm is.
Thanks
Hi,
Thanks
Hallo Peon
Hier ist die Beschreibung der AVComm
es hilft sehr, den Empfang zu vereinfachen.
und hier ist ein Bild (nicht sehr gut, ich gebe zu)
Hallo Peon
here is the description of the AVComm
it helps a lot to simplify the reception.
and here is a picture (not very good, i agree)
https://www.avcomm.com.au/shop…band-waveguide-polariser/
Low and unlocked signal on 3754 V 7500 3/4...
