This night 36B will switch to 36D.
35.9°E Eutelsat 36D <Eurasia>
If this night the transponders are transferred to the new Eutelsat 3D, it is good to know what signal differences we will see tomorrow.
That's why I'm posting the signal on the current Eutelsat 3B transponders.
36e scan now at 50cm dish.
Great, but I would like to know what signal you had before on this satellite.
I tested the signal with the circular lnb on AM1 before and after with the Toroidala90 antenna, and the third lnb on the bar, and I found that it stayed at the same level.
On Eutelsat 36D, if muxes were transferred, I noticed a slight increase in signal.
It's good to know if, on other hobbyists, the signal is the same or has increased in their area.
Eutelsat just approve that 36B now empty. All tp now works from 36D. Pls check signal difference.
From what you say, I understand that as of today Eutelsat 36D is fully used instead of Eut 36B, and Express AM1 only for the Russia spot.
The signal increased by 3 dB on the Eut 36D, but it remained the same on the AMU1.
Don't forget that AMU1 also serve africa
Here an actual scan on my location with 125 cm and linear lnb.
November 23, 2024 at 5:23 PM Changed the title of the thread from “35.9°E Eutelsat 36D” to “35.9°E Eutelsat 36D <Eurasia>”. -
