04.1°W Amos-3 <Ukraine> (OLD POSITION Feeds>Ku)
  • Ich habe gerade mal mit 125 cm und dem D15 einen Blindscan auf dieser Satposition gemacht.
    Es tauchten zwei Feeds auf, die ich auf Grund des sehr schwachen Signals auf dem ME Beam vermute
    Empfang des Testbildes ist mit Aussetzern möglich.
    I just did a blind scan at this satellite position with 125 cm and the D15.
    Two feeds appeared, which I suspect were due to the very weak signal on the ME beam.
    Reception of the testpicture is possible with dropouts.
    11177 H 5000 1/4, 1.5 dB, DVB-S, MPEG-2, VPID: 0512, APID: 4112 "GAZA Ser01", Provider: "Hezb1"
    11427 V 5000 1/4, 1.5 dB, DVB-S, MPEG-2, VPID: 0512, APID: 4112 "GAZA Ser01" , Provider: "Hezb1"
  • 11178 H,5000,1/4,S2-Gaza Ser01,
    11129 H,8000,1/2-Tandberg :3:
  • 11177 H 5000 1/4
    Today from south-west of Germany on 2.2m...
    11177 H 1000 1/4 DVB-S2 QPSK, ID: GAZA Ser01
    PS: 11170 H 1000 1/2 DVB-S, Data
    :49:FYI: According N_Stanislav on LyngSat, it´s Amos-3 on Ukraine beam... :69:
    Merged all reports now in this new toppic.
  • Danke für die Meldung , bei mir ein klein bisschen stärker
    Thanks for the message, a little bit stronger for me
  • Auch mit dem Openbox S3 HC II zu empfangen ; video ist fürchterlich
    Can also be received with the Openbox S3 HC II ; video is terrible
  • Not sure about this beam, I have here about 4-5db , other "UA" or EU TPs have 17-18db.
    UA beam does not cover Gaza...:25:
    I would say stronger ME TP.:125:
    Kathrein 220cm , KU+C,
    You can't compare using this comparison. tp7 from Amos3 can work only in Ukranian beam. Uplink to this tp on earth located near Gaza region and retransmit to Europe region. Uplink is very weak, this tp works in linear mode. That means "how stronger satellite see uplink signal - retransmit to Earth with exactly same strength".
    Same mirrored feed exist here on 11428V 1000 1/4
    For example signal at my location:
    And same mirrored in ME beam
  • 11170 H can be broadcast in 3 beams, 11430 V in 2 beams
  • 11177 H 1000 1/4 DVB-S2 QPSK, ID: GAZA Ser01
    ...weak signal today on 11177 H 1000 1/4 ...
    I can see this one in 11427 V 1000 1/4 sperctrum too, but no lock yet.
  • Something strong on 11423H , SR around 2000
  • I can see right now:
    11425 H 5000 1/4 DVB-S2 QPSK, ID: GAZA Ser01
    PS: 11423 V 5000/7000 1/2 DVB-S were Data services
    11424 H,5000,1/4,S2-Gaza :3:
    11674 V,5000,1/4,S2-Gaza Ser01,new(?)
  • 11674 V,5000,1/4,S2-Gaza Ser01,new(?)
    This one is impossibe on my QTH, according signal from 11678 V 29950 2/3 (5.0°W Eutelsat 5 West B)...
  • This one is impossibe on my QTH, according signal from 11678 V 29950 2/3 (5.0°W Eutelsat 5 West B)...
    Use an attenuator, and maybe you'll at least see the signal.:25:
    My smaller antenna is more suitable this time for this feed :3:
  • 11674 V locked and run with Novra S401pro.
  • Use an attenuator, and maybe you'll at least see the signal. :25:
    No, it´s impossible to "see" the signal 11674 V from Amos-7, because the "Transalpine" beam from Eutelsat 5 West B is too strong at my QTH on 11679 V... :3:
    11423H off (moved to 11156H + 11143H, now 11425H (decrease by 20 dBuV)
    feed 11414 H DVB-S2/16APSK SR-5454 FEC-2/3
    Edited once, last by EnoSat (November 9, 2024 at 8:07 PM).
