19.2°E Astra 1L
  • 18560 V 2500
    18567 V 1000
    18411 H 6500 , not locked yet but not perfectly set on the focal point..
  • Wow!
    Thanks Feedsat. Now also in Continuous List. :)
    Ku-band LNB: Invacom SNF-031
  • List update! the Continuous frequency on 18411 H has left
    - NS2000 - TM1 - TC1 - SR1
    - ADV-6000S - MATRIX DEV1982
    - Promax TV II+ - SMR1224EL
    - 76.5°E <> 65°W
  • 18567 V 1000 has left
    - 76.5°E <> 65°W
    18560 V 2500
    My signal of the day.
    18560 V 2500
    Signal of the day.
    18560 V 2500
    Signal of the day (1.2m).
    18411 H 6500 DVB-S2 Check with EBSpro (1.2m)
  • 18411 H , new SR 1500
    locked in BS but not in manual scan :88:
  • Always two streams found
    32APSK 9/10
    QPSK-S2 2/5
    Strong on 1.2m "garden" dish, but can´t lock it... :90:
  • Finally locked 18411 V in BS, changing SR:
    18411 H 500 DVB-S2
    [SIZE=1]PS: Can´t get manual lock with CS yet:[/SIZE]
  • 18412 H 6500 single
    - 76.5°E <> 65°W
  • 18411 H SR is now 500
    - 76.5°E <> 65°W
  • Looking around 18420 H, there are 4 ~1MHz wide signals, spaced at 10MHz on 18401.5MHz, 18411.5MHz etc and a strong carrier (40dB s/n in 1kHz) on 18405.257MHz. I can't lock any of the 4 signals but CS detects them in blind scan.
    Ku wide band: corrugated conical feed, 1.5dB NF LNA, Ku (Standard): Octagon OSLO mod for C120 & ext ref Prodelin feed.
  • The group around 18411.5H are spaced at exactly 10MHz and seem to have changed SR to 699(700). There is a 5th one, on which does not appear on CS, at 18391.5MHz.
  • Probably new SR, but unlocked here on 1.2m:
    18410 H 3750
  • Not my catch, Wolfram today in feeds-toppic: :72:
    18414 H 1250 DVB-S2,Single
  • The group around 18411.5 have disappeared from view here leaving just the carrier at 18405.2 (LNB not frequency locked)
    Edited once, last by s-band ().
  • On again on changed parameter:
    18414 L 800
