18738 L 22500 1/2 DVB-S QPSK - on again (changing Modcodes)
42.0°E Türksat 4A
Some more appeared since few days... (SimonE on satellites.co.uk forum)
18591 L 10000 1/2 DVB-S - new for the list
18703 L 22500 3/4 DVB-S - on again on new parameter, weak signal on 1.2m at this time
Better signal at this time for 18703 L.
Sorry Wolfram, I have no experiences with that feed in your link.
I am using for this position (only in Ka band) a 1.2m PFA, Norsat 9000HX-O3B-BN, XMW Ka-band Feed FD9000K and small plastic plate inside.
Here my current scan.
Original von Wolfram
Ist es warscheinlich möglich mit diesem Feedhorn in der Nähe von Berlin mit 1,20m den Turksat 42° Ost KA und auch KU gleichzeitig zu empfangen?
Gruß WolframThis feedhorn with a band tap is for linear polarization. You still need a depolarizer or insert a plate in the waveguide. Best of Teflon. The price of that feedhorn is unreasonably high.
Not so strong in UK. 1.2m dish with Gilat AN8024 ODU.
42° East Ka
18.703 L very poor here - 20k North of the City of Nottingham-UK
Todays mid-day scan of 42°East Turksat Ka. Poor Ka conditions at the moment here in North Nottinghamshire, central UK.
1.2 Gibertini / Gilat modded Band B rx board / Gilat Circ poloriser & feed motorised / Lnb changer.
February scan in circular left - really bad here on 1.8m PFA...
My current circular left scan (at 10.30 a.m.).
/edit: scans
at 1.15 p.m. - parameter for 18703 L
at 2.30 p.m. - "smooth lock" (-10dB shown via CS) on 18703 L
at 3.30 p.m. - up to 3.2dB on 18703 L >>> second maximum signal of this day
at 8 a.m. (next day and summer time) >>> looks like first maximum of the day
April`21 scan in circular left on 1,2m dish and AN8024 transceiver.
Five locks are possible at this time.
18633 L 22500 3/4 DVB-S "on the limit" - can´t get content.
18073 L not lockable - only "smooth -10.0dB" /edit: 3.1dB (later) - still 0.9dB under LM
...getting PIDs - got them in last scan already later, but thought about fake first...
/edit:
..."weak" screenshot later on 18633 L (up to 4.6dB - very instable signal)
18703 L 22500 3/4 DVB-S - only +0.4dB for a lock at this time
Finally locked 18703 L in manual on the limit - content failed (1.8m)... wasn´t possible on yesterdays scan.
Good situation right now. Getting "content" on 18703 L on the limit - without stable signal. 18633 L okay.
Bevor ich die Antenne wieder auf 19.2° Ost zurückdrehe, habe ich heute nochmal auf das KA Band vom Türksat 42° Ost geschaut. E werden 4 Transponder eingelesen, einer davon ein Datentransponder und 3 weitere Frequenzen.
Habe gerade mit der C.M. 1,80m probiert
erscheint nur zwei frequenz , bei mit stärker in V als in H ( soll normalerweise H sein )
I just got with the C.M. 1.80m tried
appears only two frequencies, with stronger in V than in H (should normally be H)
