42.0°E Türksat 4A
  • 18738 L 22500 1/2 DVB-S QPSK - on again (changing Modcodes)
    Ku-band LNB: Invacom SNF-031
  • Some more appeared since few days... (SimonE on satellites.co.uk forum)
    18591 L 10000 1/2 DVB-S - new for the list
    18703 L 22500 3/4 DVB-S - on again on new parameter, weak signal on 1.2m at this time
  • Better signal at this time for 18703 L.
  • Sorry Wolfram, I have no experiences with that feed in your link.
    I am using for this position (only in Ka band) a 1.2m PFA, Norsat 9000HX-O3B-BN, XMW Ka-band Feed FD9000K and small plastic plate inside.
    Here my current scan.
    Original von Wolfram
    Ist es warscheinlich möglich mit diesem Feedhorn in der Nähe von Berlin mit 1,20m den Turksat 42° Ost KA und auch KU gleichzeitig zu empfangen?
    Gruß Wolfram
    This feedhorn with a band tap is for linear polarization. You still need a depolarizer or insert a plate in the waveguide. Best of Teflon. The price of that feedhorn is unreasonably high.
    TBS5925, TBS6983, TBS6903, TBS6903x, TBS6903x V2, TBS6522, TBS5520SE, TBS5927, TBS5590, Prof7301, PF 250cm, ADE antenna 370cm, Full band LNBs: S, L, C Norsat PLL ,X PLL, Ku NJR2842S PLL, full Ka band PLL, and other iron for DX reception, 53W - 98E.
    Original von Peon
    Peon Thank you! And I didn't think about polarization.
