RF notch filter for suppressing intense interference
  • You probably remember my post about the impossibility of reception in the C range due to powerful out-of-band interference in the "Small talk" section.
    I thought a lot about how to suppress this interference or the interference that I have at 10730 MHz and interferes with reception at the beginning and throughout the Ku range.
    I thought for a long time, and recently calculated and made a rejection filter in five minutes, which is shown in the figure
    { Rejection 10700 MHz -24 dB }
    I was counting on a rejection frequency of 10700 MHz, so as not to completely cut off useful frequencies at the beginning of the Ku range. In fact, it turned out that the interference on the original spectrum, which is drawn by the blue curve at a frequency of 10730 MHz, after the inclusion of a rejection filter in the gap of the antenna cable is suppressed by 24 dB (see the black curve on the spectrum)
    { Rejection 10730 MHz -24 dB }
    At the same time, the local minimum of the noise level is at frequencies of 10640 - 10740 MHz.
    And C/N at a frequency of 10390 MHz increased by 5 dB!
    Please compare the results of the blind search during registration after the inclusion of a rejection filter in the antenna cable and before (without a filter) in the figure:
    { Before_&_after_Rejection }
    { Without_Rejection }
    Pay attention to the 11263 MHz transponder, whose "legs" are exactly at the noise level along the black curve, and the transponder lock reserve has increased by 2.9 dB!
    And the SNR of the 11881 MHz transponder has increased from 16.9 on the original (blue) spectrum to 18.4 dB with a rejection filter, i.e. by 1.5 dB.
    The 11895 MHz transponder, which was not locked without a filter, after the inclusion of a rejection filter received a confident lock with SNR = 17.4 dB!
    This post is based on my article Notch Filter on my blog
    Welcome back after a long time :74:, when I wondered what happened to you under war conditions in your country. I hope you are well.
    And as usual, you don't come empty-handed, but with an invention, which interests me at least. That filter you made might be valid for me, too, since I have interference in the Ku-band. Did you try it in C-band, if you can receive this band?
    I was wondering if it would be possible to make one for me, for a fee, including shipment.
    What do you say? :3:
  • Dear strannik!
    A few years ago I read a Hungarian Satellite DX-r book or magazine published in the 1990s, and which this very solution was proposed and described, for KU band applications.
    (Of course we know this theory, beacause we learned it anno, but for some reason we always forget to apply it... :-) )
    Congratulations on your work, I'm going to my library dig through...
    Regards.
    SaTom
    Andrew 370 cm PFA (26E/28.2E UK); Parsat 220 cm PFA; Kunhegyesi180 cm PFA ; Visiosat 96 Gregorian, SkyDSL 80 OA, 55 Military OA,
  • . . . Notch filter of frequency 10724 MHz . . .
    filatov_yuri
    March 14th, 14:59
    14 March 2025 - Филатов Юрий ака СТРАННИК
    14 March 2025. Спутниковое телевидение
    filatov-yuri.livejournal.com
    Vertical polarization spectrum with intense (-35 dBm) interference at frequency 10724 MHz
    Intense interference at frequency 10724 MHz (intermediate frequency 974 MHz) creates a strong background of intermodulation interference, which degrades the reception of satellite signals in the entire Ku range.
    To combat this interference, a filter was designed and tested from two sections of coaxial cable, an RF tee and three F-type connectors.
    A rejection filter is connected between the satellite antenna drop cable and the PCI-exp card input. The spectrum obtained with this setup with the results of a blind search is shown below.
    Vertical polarization spectrum with a rejection filter, which suppressed intense interference by 17 (-24) dB
    Interference suppression at a frequency of 10724 MHz was 17 dB, which had a very favorable effect on the SNR of useful signals. It increased by 0.2-1.9 dB. In addition, a signal from two more transponders was additionally received, one of which with SNR = 9.7 dB!
    Below you can compare the spectra WITHOUT a notch filter (on the right) and the same frequency ranges recorded WITH a notch filter (on the left):
    Beginning of the Ku band — spectrum with a notch filter on the left, spectrum without filtering on the right
    SNR gains (from left to right) were 0.2, 0.3, 0, 9.7 and 0.9 dB
    Middle part of the Ku band — spectrum with a notch filter on the left, spectrum without filtering on the right
    Here the gains are 0.4, 1.0, 1.9, 0.7, 0, 0.5, 0.3, 0.7, 0.1, 1.0, 1.5, 0.5, 0.3, 0.5, 0.6, 0.9, 0.9, 1.0, 0.9, 1.1 dB
    End of the Ku band — spectrum with notch filter, on the right is the spectrum without filtering
    At the end of the range, the gains are 0.5, 0.3, 0.5, 0.6, 0.9, 0.9, 1.0, 0.9. 1.1, 1.2, 0.8, 0.6 and 0.7 dB.
    My costs for making the notch filter were only $0.57
    What do you say?
    What can I say?
    Taking money from old friends and colleagues is not in my rules...
    As one wise fisherman said when he was asked for a fish:
    "I will give you a fish, but you will be full for one day.
    I will give you a fishing rod, and you will be full for life" :126:
    I will describe the design of the rejection filter and help calculate and adjust it, and you yourself will cut two pieces of coaxial cable with a known coefficient of electrical shortening, screw on three F connectors and close the appendix with a metal cap from a ballpoint pen.
    First, please make a spectrum of the working frequency range with the spectrum of the intense interference that you want to suppress in IQmonitor. And publish it here, in the topic.
    Display Spoiler
    By 1990, I had been teaching a course on wave theory at the university for 15 years and I didn't need to invent anything...
    By the way, a joke:
    Two associate professors meet and one says to the other: :101:
    "Oh, Ivan Petrovich! What a dumb student we have these days! I explain the properties of a half-wave open line to them, but they don't understand! I explain it a second time - they don't understand! I explain it a THIRD time, I already understand it myself, :77: but they don't want to!!!"
    I didn't copy anything from anyone, I simply understood the laws of wave reflection and applied this knowledge in practice when a problem with an interference wave arose.
  • Dear strannik!
    It is especially difficult to write in a forum in a way that is not misunderstood, especially when it is done in a foreign language, since there are no conditions for verbal communication, e.g. due to facial expressions or tone of voice, but the writing does.
    No one claims that what you wrote is copying, on the contrary, it fills one with joy to read again a piece of writing that one has read and studied before, but then for some reason has sunk into oblivion.
    Perhaps you were the one who inspired that Hungarian author, perhaps you even taught him, and in the end he made a publication out of it. Of course, your work and your helpfulness are both worthy of respect!
    An idea to avoid misunderstandings: I, the always start reading a reaction to my post or writing by assuming maximum good intentions on the part of the person responding. This way, the meaning of the text you are reading can change even if not a single letter has changed. This helps to avoid many misunderstandings.
    Best regards,
    SaTom
  • Hallo,
    Das nannte man Früher Stichleitung....
    Zur ausblendung störender Frequenzen in Antennenanlagen.
    Interressant, das es in der ersten ZF auch funktioniert.
    Gruß, Chromo
  • Ohne DC-Blocker muss es jedenfalls eine offene Variante sein.
    Im Radiomuseum findet man eine deutsche Beschreibung der Stichleitungen:
    Without a DC blocker, it must be an open version.
    The Radio Museum contains a German description of the stub lines:
    https://www.radiomuseum.org/forumdata/upload/hf_leitungen.pdf
  • I was wondering if it would be possible to make one for me, for a fee, including shipment.
    I offered to make a filter together and for free. To begin with, I asked to make a spectrum of the range of interest to you, on which the interference would be visible:
    In IQmonitor, unlike other similar programs, there is a gray scale at the bottom of the spectrum, which is not striking, but which displays RF frequencies regardless of the range of received waves, the frequency of the first heterodyne and the method of conversion (up or down) of useful signals.
    These frequencies (the beginning and end of the operating range), as well as the frequency of intense interference at the Z receiver input, are the basis for calculating the length of coaxial lines in the rejection filter.
    If for some reason you change your mind - let me know - we will wait until someone is really interested in this (no longer mine) problem.
    femi
    Many thanks for the link to the pdf file. Unfortunately, it is copy-protected and cannot be translated into Russian... And I do not know German, although I had two graduate students from Germany on an internship (Frank Volkersdorfer and Catherine Schöne, with whom we communicated in English).
    I was pleased to look through the articles that are my peers and which I see for the first time. I looked through the drawings, graphs and formulas - they fully correspond to the classical theory of wave propagation in lines.
  • I offered to make a filter together and for free. To begin with, I asked to make a spectrum of the range of interest to you, on which the interference would be visible:
    You overwhelm me, dear strannik, with your generosity, in the not-at-all peaceful conditions in which you live.
    I don't know if you need to be given a video demonstration of the interference affecting frequencies between 11556-11612 MHz, even towards 11700, as you see from the video made at 53.0E(sorry for the sound).
    (Forgive me for not having done the test this time with your application, IQmonitor.)
    You can see this massive attenuation at 62.0E, between 11560-11620 H, between two strong signal transponders at 11471 H with over 19dB and 11656 H with 16dB. As you can see, the transponders between these two have such a diminished signal that they barely show up on the spectrum on cloudy days.
    Can you please clarify to what extent the rejection you are talking about on a specific part of the band leads to the total elimination of the affected frequencies? In other words, what do I lose on a part of the band if I gain nearby transponders?
    I appreciate and am grateful for all you do for me and enthusiasts everywhere, not just on this forum. :70:
  • Englische und russische Version der Datei.
    Russisch sollte der Translator noch ein wenig üben.:101:
    English and Russian versions of the file.
    The translator should practice Russian a little more.:101:
    Английская и русская версии файла.
    Переводчику все равно следует немного попрактиковаться в русском языке.:101:
    :!:valid until Sunday, May 11, 2025
    file2send
  • You overwhelm me, dear strannik, with your generosity, in the not-at-all peaceful conditions in which you live.
    Я ценю Вашу иронию по поводу небывалой "щедрости" в условиях военного времени, ведь Вы наверняка читали
    57 центов - это копейки в нашем понимании.
    Гораздо хуже, что Вы не понимаете, что я от Вас хочу - СПЕКТРЫ полезных волн и волны-помехи как функцию мощности сигнала от радиочастоты на входе Вашего приёмника. Знаю, что у Вас есть программа IQmonitor, с помощью которой это делается за пять минут, и Вы нею умеете пользоваться. Не хотите пользоваться - насильно мил не будешь - сделайте спектры на любом другом программном продукте или спектро анализаторе. Вам для расчёта заградительного фильтра нужны именно RF частоты. И выберите, пожалуйста, один объект для наших показательных расчётов режекторного фильтра
  • Я ценю Вашу иронию по поводу небывалой "щедрости" в условиях военного времени, ведь Вы наверняка читали
    Thank you for your reply, and why shouldn't I say it touches me? I didn't mean any irony towards you or the situation you find yourself in.
    I want to assure you that there is no irony in the living conditions you are forced to endure. On the contrary, it showed my sympathy for what is happening in your country during wartime. This has been my thought for all who live in Ukraine since the beginning of the war.
    The misunderstanding of my message comes from the translation; I said that your generosity overwhelms me, not that it is unprecedented.
    The translation from your language into English completely changes the meaning of the words. Synonyms for "overwhelmed" are to be deeply moved, strongly impressed, etc., and "unprecedented" is previous, preceding, etc. Other synonyms can be chosen for this word.
    The misunderstanding stems from the incorrect translation between the literal (and not literary) meaning and the figurative meaning of the words we used. Your text translated with Google from your language into English is this:
    "I appreciate your irony about the unprecedented "generosity" under wartime conditions, because you must have read it", and what I wrote is entirely different:
    "You overwhelm me, dear strannik, with your generosity, in the not-at-all peaceful conditions in which you live."
    Perhaps the quotation marks you used should have been placed around "unprecedented" and not generosity, because that word is wrong, and the latter is precisely what I think of you, a generous person, someone who does good to others. That is what I meant when I said that your gesture overwhelms me.
    But I will stop here because I don't want to be misunderstood again on semantic issues when I call on a machine to do it.
    I assure you that you have my sincere gratitude for what you do for us, enthusiasts on this forum or elsewhere.
    As for the rejection filter you created, I have now carefully read what you wrote about it and the tests you did. I will try to do it myself with your IQmonitor and then post on this topic.
    My best regards :70:
  • Today I reverse engineered the "silver" notch filter to show its design and, at the same time, to increase the notch frequency. First, I unscrewed the quarter-wave section of the filter (1) from the tee:
    Then I removed the protective cap from the ballpoint pen as shown in photo (2) :
    The open end of the coaxial cable (I used a Finmark 690 cable, in which the insulator is foamed polyethylene, with a shortening factor of 0.86) is wrapped with black electrical tape to prevent the central core from shorting to the cable braid, and it to the outer screen.
    In the figure (3) the insulation is unwound, and two marks with a black felt-tip pen are visible on the cable:
    - the first is at the calculated distance from the bare end of the central core and along it the cable was cut after winding the F connector;
    - the second is applied exactly according to the size of the cable, which is hidden under the blue cap of the first copy of the rejection filter, the rejection frequency of which is higher and is at the bottom of the Ku range.
    Finally, you can see in the figure (4) how the cable was cut with metal scissors. The cable deformation was eliminated by finger-crimping, and before insulating with electrical tape, the absence of a short circuit of the foil or wire braid hairs on the central core of the cable, which should be strictly on its axis, was checked.
    Having insulated the end of the cable and inserted it into the handle body, I screwed the quarter-wave section of the rejection filter onto the tee.
    Having registered the spectrum, I made sure that the rejection maximum had shifted up in frequency, remaining below the beginning of the Ku range.
    In general, the spectrum has changed for the better and has become noticeably cleaner, and the SNR of many transponders has increased, especially in the area of the 3rd and 5th subharmonics:
    The strongest effect was observed for horizontal polarization:
    A pleasant surprise for me was the 11069 H transponder, which I had not seen before in the shadow of its powerful neighbors... :12:
  • Today I reconnected the antennas:
    - the 90°E antenna, which was connected via the "blue" notch filter to the A input of the TBS 6983, was connected via the "silver" notch filter to the B input of the TBS 6983;
    - the 42°E antenna, which was connected via the "silver" notch filter to the B input of the TBS 6983, was connected via the "blue" notch filter to the A input of the TBS 6983
    I loaded the spectrum of 42°E registered yesterday from the database and displayed it on the tablet in gray, as a basis for comparing the spectra. I registered the spectrum of 90°E in blue on it, and then registered the spectrum of the vertical polarization of the 42°E satellite in purple:
    From the comparison of the spectra it clearly follows that the interference waves in the RF frequency range of 970 - 1010 MHz are interference on the cable from the antenna and they are completely suppressed by the "blue" rejection filter. "Blind" scanning of the satellite position 42°E was carried out, which confirmed the high efficiency of the filter, especially when receiving on the 3rd and 5th subharmonics of the internal heterodyne, as well as on horizontal polarization:
    :70:
