Kann mir bitte jemand erklären, was "ACM Kontrolle An, Aus" in den Einstellungen des Satreceivers bedeutet?
Can anyone tell me please, what "ACM-Control on, off" in the menue of a satellite receiver means?
Möglicherweise AudioControlModule, sicher bin ich mir da aber nicht.
ChatGPT:
On satellite receivers, ACM stands for Adaptive Coding and Modulation.
It’s part of the DVB-S2 and DVB-S2X standards and is mostly used in professional broadcast and data links, not consumer DTH (direct-to-home) TV.
Here’s the idea:
VCM (Variable Coding and Modulation) → lets the operator send different streams within the same carrier using different coding rates and modulations (for example, one PID in QPSK 3/4, another in 8PSK 5/6). Each service has a fixed modulation/coding chosen by the uplink, but can differ between streams.
ACM (Adaptive Coding and Modulation) → takes it a step further. The modulation and coding of a given stream are adaptively changed in real time depending on the reception conditions (rain fade, dish size, link budget). The return channel (feedback from the receiver or terminal) tells the uplink what the channel conditions are, and the uplink adapts accordingly.
Where it’s used:
Broadband VSAT and professional links → ACM is essential for maximizing throughput. When the weather is clear, the hub uses high-order modulation (like 16APSK, 32APSK) with high FEC efficiency; during rain fade, it falls back to QPSK/3/4 or similar robust settings.
Contribution feeds and some IP over satellite systems.
Consumer DTH TV normally uses CCM (Constant Coding and Modulation) because the broadcaster cannot adapt per individual viewer.
In practice:
A satellite receiver that shows "ACM" capability means it can handle adaptive/variable modulation streams (often seen on professional or feed transponders).
If a transponder is marked ACM/VCM, it won’t behave like a simple TV channel multiplex. Instead, you’ll often find multiple PLS (Physical Layer Scrambling) codes, per-stream coding rates, and sometimes it won’t lock on consumer receivers at all unless they support these modes.
👉 In short:
ACM = Adaptive Coding and Modulation, a DVB-S2 feature that dynamically changes modulation/FEC to optimize link efficiency depending on channel conditions, mainly used in professional/data satellite systems.
Here is the part of the menue that i ment:
This receiver finds on a single data transponder up to several hundrets of streams.
Could it find videocontent in such datastreams, if video is available in such a stream ,that normal receiver could not find?
Until now i had no succes, finding a videostream in a data channel with this receiver.
Gestern habe ich dann mal im Menü die Funktionen "ACM Control" und "PLSN Super Scan" deaktiviert und im C-Band auf SES5 (5° Ost) so wie auf
Eutelsat 10B (10° Ost) einen Blindscan durchgeführt.
Es wurden auf beiden Sateliten je zwei Programme mit Verschlüsselungssymbol $ (CAS unknown) unter den Radios abgespeichert.
Ggf. ein Hinweis auf einen gefundenen und eingelesenen Datenkanal?
Ich habe die PVR Funktion aktiviert, aber die aufgezeichneten Dateien hatten 0 MB.
Yesterday I deactivated the "ACM Control" and "PLSN Super Scan" functions in the menu and carried out a blind scan on SES5 (5° East) and
Eutelsat 10B (10° East) in the C band.
Two programs with the encryption symbol $ (CAS unknown) were saved under the radios on both satellites.
Possibly an indication of a data channel that has been found and read in?
I activated the pvr function, but the recorded files had 0 MB.
1. SES 5:
Parameter: 3991 L 51427 Auto (Rest siehe Screenshots).
Kennung:
1. Unname
2. E__AG_E5_EH_N01_555
Aktuell wieder aktiv!
Im Info Menü war zu sehen, dass die Modulationsparamenter wechselten zwischen S2 und S2X, so wie zwischen DUMMY, QPSK, 8PSK,
16 und 32 APSK.
Videotyp: MPEG1 Audio Typ: MPEG1, Auflösung: 720*576.
1. SES 5:
Parameters: 3991 L 51427 Auto (rest see screenshots).
Identification:
1. Unnamed
Actually active again!
In the info menu one could see that the modulation parameters changed between S2 and S2X, as like between DUMMY, QPSK, 8PSK,
16 and 32 APSK.
Video Type: MPEG1 Audio Type: MPEG1, Resolution: 720*576.
2,Eutelsat 10B:
Parameter: 4014 L 28048 Auto (Rest siehe Screenshots).
Kennung:
1. Unname
2. Shared_E10B
Aktuell noch aktiv.
Im Info Menü ist zu sehen, dass die Modulationsparamenter wechseln bei S2 zwischen DUMMY, QPSK, 8PSK, und
16APSK.
16APSK.
2, Eutelsat 10B:
Parameters: 4014 L 28048 Auto (rest see screenshots).
Identification:
1. Unnamed
2. Shared_E10B
Currently still active.
In the info menu you can see that the modulation parameters change for S2 between DUMMY, QPSK, 8PSK, and
16APSK.
In the info menu i can see that the modulation parameters change for S2 between DUMMY, QPSK, 8PSK, and
16APSK.
Im Info Menü war zu sehen, dass die Modulationsparamenter wechselten zwischen S2 und S2X, ...
Wohl die Folge der ausgeschalteten ACm Control.
These are mostly IP transponders of the following types:
Display More2,Eutelsat 10B:
Kennung:
1. Unname
2. Shared_E10B
Aktuell noch aktiv.
16APSK.
Videotyp: MPEG1 Audio Typ: MPEG1, Auflösung: 720*576.Im Info Menü ist zu sehen, dass die Modulationsparamenter wechseln bei S2 zwischen DUMMY, QPSK, 8PSK, und
16APSK.
2, Eutelsat 10B:
Identification:
1. Unnamed
2. Shared_E10B
16APSK.
Video Type: MPEG1 Audio Type: MPEG1, Resolution: 720*576.In the info menu i can see that the modulation parameters change for S2 between DUMMY, QPSK, 8PSK, and
16APSK.
Ergänzend die CS Auswertung.
Erstaunlich, dass der Receiver da was einliest.
Ganz nettes Kästchen, vom Gewicht her ist eigentlich nichts drin
Hab das Teil schon eine Weile,
konnte mich noch nicht viel damit befassen.
Scan auf 57°Ost, ACM On, PLSN On.
Grüße Kathrein018![]()
Für eigentlich nichts drin kann es eine ganze Menge mehr als manch anderer Satreceiver dieser Preisklasse.
Vernünftig durchdacht ohne viel Schnick Schnack drum rum.
Logische Menüführung.
Macht wirklich Spass, diese kleine Kiste.
Mit den beiden deaktivierten Funktionen findet der Receiver anscheinend auch den ein oder anderen Datenkanal und liest ihn als Radio ein.
Mit aktivierten Funktionen findet er nur die Transponder.
Ich gehe übrigens davon aus, dass das Gerät die S2X Modulation verarbeiten kann.
Ist vielleicht etwas naiv gedacht, aber ich hoffe ja immer noch auf Videocontent in einem dieser eingelesenen Datenkanäle.
Hier gibt es wohl noch einige Überraschungen zu entdecken. ![]()
PLSN Super Scan:
Wenn Sie „An“ ausgewählt haben, findet der Receiver
beim Sendersuchlauf „BLIND SCAN“ auch schwächere
Sender. ( laut I-Net)
Beim Paksat: ACM off, PLSN on: Scandauer ca.11 Minuten, hier taucht dann plötzlich 3834 H auf, weit unter Lock ![]()
ACM & PLSN off Scandauer ca. 3.30 Minuten.
Es gibt hier wirklich viel zu entdecken.
Immer wieder was Neues.
Der Receiver läuft stabil und schnell.
Was ist I-net, bin noch nicht dahinter gestiegen.
Die Netzfunktionen habe ich noch nicht getestet, habe immer per USB upgedatet.
Vor allem, regelmäßige Updates, manchmal bis zu drei pro Monat sind hier Standard.
Info aus dem "Internet".
Nicht am Netz? Dann hast du ja nicht die ganzen "Sonderfunktionen " genießen können. ![]()
Wenn es bei dir überhaupt noch funktioniert...
Beim Einlesen von verschlüsselten Feeds ist mir erstmalig aufgefallen, dass neben BISS auch BISS1 angezeigt wird.
Ich habe immer die aktuellste Firmware drauf, habe mir aber alle verfügbaren alten Updates runtergeladen. Das sind sehr viele verfügbare Updates. Mit der ersten Firmware Generation im alten Look waren auch niedrige SR kein Problem.
Mittlerweile werden die nicht mehr so gut empfangen.
Hallo qwer,
kannst du bitte der Ordnung halber vielleicht ACM Control in
SR-200HD EXTREME 4K umbenennen, somit weiß jeder worum es sich
hier handelt...
Danke im voraus!
Grüße Kathrein018 ![]()
Ausser uns beiden dürften den Receiver wohl nicht viele User hier im Forum haben.
Interessant,habt ihr 2 auch eine Bezugsquelle/Link zum Produkt ![]()
