Hello,
I had ordered two month (!) ago - the package took forever to ship and was retained at customs for 3 weeks - a LibreSDR B220 from AliExpress, benefiting from their Black Friday/Christmas sales. This device is a (much cheaper) clone of the Ettus USRP B210 SDR, somehow similar to a Adalm Pluto, but featuring a USB-3.0 connection and a AD9361 (instead of a AD9363, configured out of specs as a AD9361). It has two independent RX/TX ports, which makes it suitable for Es'hail amateur radio, but I am not into that.
What really interests me is the RF spectrum and demodulation of the signals.
The following picture shows VMA Stream Reader tuning to BOM Cine (10913MHz - H SR2499) at Hispasat 30.0W. This however was done for two purposes only: to rotate the dish and provide power to the LNB (including polarity and band selection).
What is not visible is my setup:
TBS6903X ---> Input 1 of simple "T" connector
B220 ---> DC Blocker --> Input 2 of simple "T" connector
Input 3 of simple "T" connector ---> LNB
On the PC, SDRangel is running, configured center frequency 1163MHz (10913MHz-9750MHz).
It is running the "DATV Demodulator" "channel":
So what is happening here is that we are using a Software Defined Radio (SDR) to demodulate in software a commercial DVB-S2 transponder!
Of course I selected this transponder because it has a BW of 3MHz and only one channel, making it an excellent test transponder.
All of this should be possible with a cheaper HackRF One or Adalm Pluto (or one of the many clones).
What is amazing, though, is using 16MHz of bandwidth thanks to USB-3.0:
Suddenly you can see all the pilots!
And to finish, SDRangel showing a whopping 50MS/s:
I found it interesting to look at this from an SDR, which has a much higher resolution that what we are normally used to:
