Just my todays scan after a long time - only 1.6° elevation for this position - signal is going up and down...
83.0°E Gsat-10
First reception of Gsat-10.
During my last scan of sat i noticed that G-Sat-10 (Ver tps) comes much lower than Insat 4A (Hor tps ). Especially at freq range 11450-11700 is almost impossible to locked anything from here.
Best signal has the 11010 Hor -
Original von Kypros_Pambou
Best signal has the 11010 HorIn my area the signal is maintained at the same level.The coolest I ever had was between 11450-11700 MHz.And now it is the same.
Probably with the 2.20 antenna it might lock,at least one transponder
Here's how the signal looks atm -
My yesterday's blindscan with 3.4m and cloudy weather conditions.
Few locks today.
Todays scan . LO of my LNB is crazy(+2).
Just my bad scan here (1,6°Elevation).
The signal is weaker than it was on the satellite that left the position.
/merged in this toppic by qwer.
Todays scan
hvdh: moved to existing topic.
Todays Scan .
No spectrum visible from my place since about two years. Changed my last Ku-position now to 80.0°E...
/edit: incredible - just starting "my last scan" - a small non-locked signal appears!
All Ku-band transponders now switched off from this satellite
