Arclamp,
Welcome to the Forum, and thank you for sharing your excellent software.
Arclamp,
My pleaseure. for the TBS thing. can they subbmit a PR to the github
Just an update: I have support for Pluto and B210. Working on RTL support. I only compile for Windows.
I am not sure how to share this back to you, though. Not much GitHub experience.
Great work you did!
No problems just give me a link to the source code and make a git hub account and ill credit you after intergeneration
Hello,
The complete package with source code and Windows binaries can be downloaded here:
https://vma-broadcast.com/DecSAT_HackRF-Pluto-B210-RTL.zip
Regards,
Vitor
Thanks, @Vitor, for the improvements you’re making to this app. I’ve only managed to install the basic version.
From what I’ve read in this thread, it seems RTL-SDR and NooElec dongles are bandwidth-limited, so you can’t capture satellite signals ( ? ).
Am I wrong? Please let me know which dongle I need to support a higher bandwidth. ![]()
The RTL dongles are almost useless, you can receive digital transmissions with a bandwidth of up to 1MHz <> Symbol Rate of 1.000kS/s. Also, they normally only tune up to 1MHz or 1.8MHz, depending on the tuner used.
This means that you won't be able to tune above 11.550MHz in Low Band or 12.400MHz in High Band, unless you have a frequency converter like the moRFeus (https://www.crowdsupply.com/othernet/morfeus) or similar.
So, these dongles are unsuitable due to limited frequency range and too low bandwidth.
The next step is to get a PlutoSDR. These are widely used by radio amateurs for Es'hail transmissions, including DVB-S2, but with small bandwidth of 500kHz. This device is available as an original Adalm Pluto or as cloned Pluto+ or LibreSDR Pluto. The clones are better, because they have 2x RX/TX, while the unmodified Adalm Pluto only has 1x RX/TX (older releases cannot be upgraded to 2x RX/TX).
With my tests, unfortunately, the best results are at just 8MS/s. While, in part it might be due to lack of testing and lack of optimization in the code, the main reason for the poor performance, compared to the HackRF, is the fact that samples are 12bit instead of 8bit on the HackRF. And, this device uses USB-2.
The best device is the HackRF One. It will run at 20MS/s and demodulate transponders with up to SR 10.000kS/s. The problem is that it seems to be sold out at AliExpress (clones were available at 100-150 Euro). The few ones I saw on sale cost around 300 Euro. I believe this is because of the new HackRF Pro, which is even more expensive.
And then finally, there are the Ettus B210 clones at AliExpress. They are OKish. Great specs (up to 60MS/s, USB3), but I never had results over 40-50MS/s (with drops). And they are not supported by many SDR applications. But they do work. Unfortunately, the prices increased considerably, too.
This is why I cannot recommend any device.
Display MoreThe RTL dongles are almost useless, you can receive digital transmissions with a bandwidth of up to 1MHz <> Symbol Rate of 1.000kS/s. Also, they normally only tune up to 1MHz or 1.8MHz, depending on the tuner used.
Thanks for publishing this, I just tried it with my E4000 RTL-SDR and it picks up the device successfully. However, the frequency limits that are hard coded only apply to the R820T so I'm unable to tune the highest frequencies. The E4000 chip will tune up to 2200MHz (rather than just 1766MHz), so this is incorrect. I've confirmed reception of frequencies that high up via this version of the RTL-SDR in other SDR apps.
The gain steps are also slightly different for E4000 versions, but I haven't had chance to look at these yet
Today I received the OpenSourceSDRLab HackRF Pro clone.
Everything went smooth, purchased October, 25th and received today, November 6th. This is less than two weeks and I had zero customs issues. The price I paid included free shipping and all taxes. I must say that AliExpress handled the new EU import norms very well.
The item arrived and works. The bad news for me, but good news for you: I paid 186,89€ and the price is now on "11.11 Sale" for 150,05€!
https://pt.aliexpress.com/item/1005012450470775.html
This is a 1:1 replica of the open source HackRF Pro, which replaces the HackRF One (https://greatscottgadgets.com/hackrf/pro/).
It uses the exact same FW (I upgraded the FW with the latest version). The "hackrf_info.exe" tool identifies this version as an unofficial version, but otherwise it works just the same. The following picture shows the output with the HackRF Pro clone and an original HackRF One:
My (quick) tests today show me that there is a real improvement over the original HackRF One:
It has less spurs and noise and better amplification.
It is supposed to have fixed the hardware weakness where a strong transmitter could easily blow the HackRF One built-in amp (happened on one of my 3 HackRF One...).
For you satellite enthusiasts:
MPE/IP radio stations:
Note: For satellite I am using the TBS6903-X to power the LNB and set satellite, polarity and band. This works with any supported TBS receiver.
And I am using TWO HackRF (the HackRF One for the Wideband overview and the HackRF Pro for the demodulation). This gives me a live spectrum with 4 Hz over a 1200MHz span! For those unfamiliar with spectrum analysis: it is a spectacular!
The Wideband overview panel can be undocked, which transforms it into a full spectrum analyzer implementation:
None of my (many) satellite field meter come close to these possibilities.
The spectrum is incredibly detailed with super refresh rate. A 80MHz span will refresh at more than 50Hz! That is REALTIME spectrum quality!
So, what do you need in terms of investment?
Of course a dish, LNB and a CrazyScan compatible tuner.
Then I recommend two HackRF Pro - at 150 Euro each, you invest 300 Euro. Buy in two separate shipments!
Buy all the adapters (SMA to F), buy quality DC Blocker (very important) - I use Televés Ref. 4071 and get a splitter to drive both HackRF on the same signal cable as the TBS tuner.
One important detail: the HackRF is very popular in combination with the Portapack.
This is an add-on board with screen and buttons. The newer releases come with battery, speaker and mic (older ones need external USB power pack and headphones with mic). It attaches to the HackRF and allows mobile use and constitutes one of the most popular hacking devices.
It can be used as a normal HackRF, too, by entering the original HackRF mode.
The most popular firmware is this: https://github.com/portapack-mayhem
Now the important part: the HackRF Pro has a different PCB layout, designed to allow the implementation of a Portapack that leaves enough room for a 18860 battery (https://www.sdrstore.eu/hackrf-h4m-pro…arging-runtime/).
This, however, makes the HackRF Pro incompatible with all Portapack's, except this one: https://pt.aliexpress.com/item/1005012864709382.html
If you have a HackRF One, you need to buy the regular Portapack.
Again: there is no need to buy the Portapack, but it is a cool add-on for when you are on the road, away from the computer. It will, of course, not offer the functionality of SDR software like VMA Radio Lab. If you get the Portapack, you will still be able to attach the device to the PC and use it as a normal HackRF Pro.
What about the URSP UHD B210 clones?
They have two things that are better: they can run at 40MS/s while the HackRF One/Pro can only do 20MS/s and they have 12bit resolution, while the HackRF One/Pro have only 8bit resolution. Still, everything in VMA Radio Lab works, including ATV in colour and teletext - which is a great benchmark on the resolution.
The B210 is worse in one thing: every time you start it, the FW is transferred to the FPGA. This takes about 5 seconds (maybe a bit more). It is a bit annoying when starting or changing the sample rate - it causes a 5 second interruption. With the HackRF One/Pro the start is immediate and so is the changing of the sample rate.
The cheapest B210 clone I found is this one: https://pt.aliexpress.com/item/1005012704880285.html
Note that I am only considering reputable sellers like OpenSourceSDRLab.
If you have any questions ask me.
This setup is far superior to any TBS tuner or application that only relies on CrazyScan streamreader.dll. No matter or small the SR, you will see and be able to analyze the signal. The many modulation standards (digital and analog) allow to extract the most possible information. For example, there is ZERO problem in tuning small transponders that are close to big transponders.
I would say that "hardcore satellite DX" or "HAM DX" has definitely entered a new age with SDR. The TBS tuners are still valuable for transponders with big SR (>10.000kS/s). But for everything else, I have no doubts that SDR is better.
