• Those waiting for a 5927SE USB version with an S2X extension can now try it out.
    The TBS specification lists the following features:
    TBS5927SE is the successor of TBS5927, a professional-grade digital satellite TV tuner USB box with USB2.0 connectivity for PCs. s Beyond standard DVB‑ S2X/S2/DVB-S QPSK and 8PSK supported by ordinary satellite receivers, it delivers advanced professional reception modes including ACM, VCM, Multi-Input Stream, 16APSK, 32APSK, Multiple Generic Stream and Combined Single Generic & Single TS — functions unavailable on most mainstream satellite receiving hardware. Equipped with built‑ in hardware blind scan, it features fast automatic blind scan over symbol rates and carrier frequencies, greatly simplifying satellite spectrum exploration. A tristate MPEG TS output interface supports flexible transport-stream export. With dedicated TBS software tools, users can capture these special broadcast streams effortlessly. Official Windows BDA drivers and Linux drivers are both supplied for broad system compatibility.
    Although the 5927se driver is incomplete for Windows, I've run a few tests that look promising. We still need to wait until we can use DVB applications on this tuner.
    It’s a pity that the StreamReader file cannot yet be used in established applications; only DVB players can be used.
    On Linux, the situation is better for the 5927se, and expectations may be met once Deeptho’s driver – which does not yet exist – can be installed for the neumoDVB app, instead of the TBS driver. I carried out an initial test with a symbol rate of 666 on 11465 H at 5.0 W, or with the RAI DAB streamer on 12564 V.
  • Code
    Good news:
    According to the specifications,the tuner operates starting at a symbolrate of 1000 KSps. Your test shows it working from as low as 667 KSps.
    Kathrein CAS 018 mit 2-Achsen Polarmount und JPC Posi
    AV Comm Polarizer + Kaons C-Band LNB KS-N201G + Bullseye TCXO Ku-Band LNB
    Fibostop 90 mit Original Polarmount , UAS 572
    Octagon FS8008 Supreme + Starsat SR-200 HD Extreme + TBS6903
  • So what’s the problem? Not everything that’s written on paper holds true in practice.
    Here’s a lower symbol rate: 11481 H, 542, 1/2-radio Nostalgie on Ubuntu 24.04.
    That’s something we should be pleased about.
  • satesco Thank you for the information, I had not heard about this unit before.
    It looks an interesting replacement for the 5927. Do you know what demod chip is used? Any internal pictures to share and compare against the 5927?
    The tbs5927se specification given at the start is actually that of the AVAlink 6162A demodulator.
    The tbs5927se specification listed at the start is, in fact, that of the AVAlink 6162A demodulator. And I think that tells us something about this USB device we were expecting to perform well; I don’t know if it’s better than the 5927, but at least it gives us access to certain parameters not found on the previous model. And it performs well!
    I hope some of the developers who visit us and help improve the performance of the applications they’ve developed will find a solution that comes close to what we achieved by replacing CrazyCat. :51:
  • Hallo Satesco,
    hast du noch weitere Tests durchgeführt?
    Bist du mit der USB-Version 5927 SE zufrieden?
    Gruß
    Digisat :84:
  • Hallo Satesco,
    Without Crazycat’s StreamReader file, I couldn't test many applications, including CrazyScan. I limited myself to the TSReader, TBS Blindscan utility and a few DVB players, particularly AltDVB.
    I’d also add that I think the driver for this device still needs some fine-tuning. And that’s hardly surprising, as I’m working with an early version of the driver.
    Even without these DVB tools – the ones we’ve been using for existing cards for a long time (I assume you’re familiar with them) – the tests I’ve carried out with the 5927Se are promising.
    One example would be locking onto muxes with a low symbol rate. I managed to lock onto symbol rates of 542 and 666 at 5.0 W on both Windows and Linux. I also tested 16-APSK and 32-APSK modes with no problems. DAB streams also play on Linux.
    I hope a developer will take the time to draw inspiration from the StreamReader file and make it usable for many DVB applications. For now, this is the only thing missing: a library similar to CrazyCat’s, so the 5927’s potential can be fully utilised, as with established cards.
    A few aspects of this tuner’s driver still need fine-tuning. I hope we’ll discover as soon as possible what this device can do once we have a fully optimised driver and the StreamReader file, which is the backbone, so to speak, of many DVB applications. For now, I’m exploring it step by step.
    I can see that it seems impossible at the moment, so let’s keep our fingers crossed that someone will provide us with such an essential file for the 5927SE tuner.:3:
  • Anyone who has purchased the TBS5927SE device can download the driver from the TBS website.
  • Ich habe eine TBS 5927 SE bei einem deutschen Shop (vor)bestellt.
    Mal sehen, wann die hier ankommt.
    Momentan ist sie noch nicht lieferbar.
    PC Card: TBS 5925.
    Aktuell genutzte Receiver: StarSat SR-200 HD Extreme, Amiko Viper 4K Combo (DAB/DAB+). Octagon SF 4008 (für schnellen Blindscan), Dreambox DM 7020 HD und DM 920 UHD.
  • Moin satdxer,
    da bin ich auf deine Auswertung gespannt bzw. dass auch die TBS UNI damit gut läuft. Treiber gibt es schon bei TBS....
    Gruß
    Digisat :84:
  • Now that no one like the brilliant CrazyCat is supporting the new TBS cards, we really miss him in our community.
    Without the StreamReader file, this device, though well-equipped and capable of many functions, lacks something important that would really bring out its best.
    I hope someone, a daring developer, will use AI to achieve the impossible: create a similar file that matches the Ukrainian developer’s performance and provides the necessary support, as it does for many TBS cards.
    The multi-stream signal is garbled, and the signal strength is significantly lower than it should be
    I also checked the PLS MUX signals at 5.0 with 5927SE, and I’ve noticed the same thing. Even though the signal is at the limit on these transponders at 5.0 W, I think the errors seem to stem from the chip itself.
    I’ve reported the errors occurring on the PLS MIS channels under Windows 11 to the manufacturer.
    In contrast, tests with the tbs5927SE on Linux, on the same Rai muxes at 5.0 W, even at 12606 V, run smoothly with the T2-MI MIS 5 streamer. I carried out the tests using the tbs drivers. Linux has the upper hand this time.
  • The multi-stream signal is garbled, and the signal strength is significantly lower than it should be
  • With driver version 1.1.0.4, all PLS T2-Mi multiplexers run normally and without any issues with tbs5927SE.
    I tested at 5.0W on 12606 V, 35300, 2/3, 7PSK PLS T2-MI and at 9.0E, 12226 V MIS 10, 20 and 12303 V, 30000, 5/6, 8PSK MIS 30, 40.
