11245 H,2000,3/4,Dvb-S/8PSK,CCM-Data
70.5°E Eutelsat 70B
Not new, just for stats.
11241 V 5012 DVB-S2, Data (?)
12680 H,5221,3/4,Dvb-S2/8PSK,ACM,Single-Packetized
11240 H is still active, nobody for a lock ?
4350 5/6 16APSK ACM Roll off 0.35 Pilot ON11244 H has left ?
11244 on,
A couple of new peaks appear between 11450 and 11530 V, maybe someone wants to check these (my dish for 70.5°E is too small)?
Yes activ for a couple of days, these peaks are unforunately not lockable with our DVB cards and receivers.
Thank you the reply (edit: including satesco below)!
Probably similar then, to the unlockable (military?) signals that used to be on Eutelsat W5/70A. -
Original von hvdh
Probably similar then, to the unlockable (military?) signals that used to be on Eutelsat W5/70A.You're probably right.
These peaks were in lowest band (Between 11100 & 11200) as you can see on this old scan. -
12534 H,5222,3/5,Dvb-S2/8PSK,ACM,Single-Packetized
...Moved to:
12515 H,5222,2/3,Dvb-S2/QPSK,ACM,Packetized -
12563 V 1000 1/2
Channel soon or DATA only ? -
Data most possible
Also the reception with 3.4m -
New Data.
12578 V 1666 3/4 DVB-S2/32APSK.
12722 V 10537 6/7 DVB-S2/QPSK. -
12704 H 3582 2/3 DVB-S2/16APSK.
Data. -
New Data.
11418 H 51433 1/2 DVB-S2/QPSK2. -
New SR.
12722 V 10656 3/5 DVB-S2/QPSK2 -
