• low level:
    check all plugs from your card to LNB
    if it's possible, test another LNB
    i have 26meter RG6 cable triset 113-pe its not long distance. Invacom adf-120 have a little weaker gain comparing to inverto black ultra.
    If weather allows i will put other LNB.
    and prof 7301 shows good spectrum, around -50dBm, so its not lnb or cable.
    I dont have any switches, diseqC etc.. just Invacom connected directly to tbs card.
    i think that AGC or VLNA is broken in this card :(
    need to remove that metal shield and see what is there.
    Dish Mabo 180cm Ku 93.5*E-40.5*W(without 76.5*E and 78*E) Ku: Edision TL-2SE C: Titanium Satellite C238 3.8GHz - 4.2GHz
    Prof 7301 S2, TBS 6983
    Poland, Lodz
  • Finally i put back Prof7301 to my PC.
    now i can do better comparison this two cards. I used Crazyscan and IQ Monitor. connected using same setup (cable and lnb)
    First prof7301 crazy scan. Default bbgain nothing changed.
    tbs 6983 with default bbgain
    now with iq monitor
    prof 7301 Vertical
    Horizontal
    tbs 6983 vertical
    Horizontal
    Now im pull out tbs from my pc and its time to unsolder this metal shielding and see what is inside. Im still wondering why TBS have such low dBm value. Almost hit the ground.
    How can i measure Noise NF using IQ Monitor Pro?
    Poland, Lodz
  • Look at
    IQmonitor tool - Satellites Community
    Guten AbendHier kommt nach viel viel Arbeit von Strannik die neue Version von IQMonitor : die version 2202.Viele neue Möglichkeiten sind jetzt dabei .Unter…
    www.satellitescommunity.de
    #1469
    or here
    25 May 2021 - Филатов Юрий ака СТРАННИК
    25 May 2021. Спутниковое телевидение
    filatov-yuri.livejournal.com
  • Hello strannik.
    Today i unsoldered metal shield from my tbs card. I also didnt have two capacitors C105 and C106.
    There are gold traces to prove better shielding.
    Still wondering why V13 is missing C58 capacitor
    can i stick to STV6120 any little heatsink? using 3m thermal conductive tape?
    then i will do better and bigger shielding from copper
  • Hi everyone, what is the minimum and maximum S/N value for the 6983 card?
    I haven't found this value elsewhere.
    Thanks
    Lodi sud
    laminas 180
    tbs 6983-6522-6903X
    rover tab 900 plus
    proform KTI h 180
  • You can look or ask here
    https://forum.tbsdtv.com/
  • Code
    sorry but I made a typing error the value I'm interested in is the minimum and maximum S/R
    Lodi sud
    laminas 180
    tbs 6983-6522-6903X
    rover tab 900 plus
    proform KTI h 180
  • Sorry, I made a mistake.
    I wanted to know the minimum and maximum S/R values.
    Thanks.
    Lodi sud
    laminas 180
    tbs 6983-6522-6903X
    rover tab 900 plus
    proform KTI h 180
  • TBS 6903 specifications:
    - Receiving frequency: 950~2150 MHz tuning range
    - Input level: -69~-23dBm
    - Dual channels DVB-S2/DVB-S 8PSK QPSK 16APSK 32APSK ACM/VCM
    Symbol rate: 200 ~ 67500 Ksym/s
    - Maximum symbol DVB-S2 rate limitations (Msymb/s)
    Msymb/s |Demod |LDPC |Single Dual
    QPSK 67.5 135 67.5 67.5
    8PQSK 67.5 90 67.5 45
    16APSK 67.5 67.5 67.5 33.7
    32APSK 67.5 54 54 27
