07.0°E Eutelsat 7B/7C
    For fans,
    it's FTA
    10961 H 9875 3/4 Super Rugby
  • 11075 V,60000,2/3,S2/16APSK-LK Enc
    It was active few minutes ago with 2 programs, one EBU promo and a 2nd with ID
    C02Gvs1 UNL Promos
    in 8PSK
    will probably back again within the minutes or later...
    active again with just the proimo on air
    just changed Modulation foir 16APSK
    They are doing many test, (SR 30msps now)
    see attached screenshots, including S2X right now
    more test with different SR (35 to 50 msps) S2 16APSK
  • 12515 V,7190,3/4,8PSK-Eco vs Fra(rugby)
    11145 H 35995 5/6 for rugby fans good quality streams
    just for the unusual SR (I think)
    11189 H 8.3 3/4
    11214 V 15165 3/4 NHL mux
    new at this position I think (maybe already reported, 2 long time without dxing...)
  • 10977 H,7200,3/4,8PSK-Webb Space Telescope launch from Kourou
  • Some feed is active at the moment, taking the whole transponder with central frequency 12560 H, but can't be locked. The SR could be 35000 ks/s.
    This is the second test of this feed, the first was two days ago, at Sunday January 9.
    Taking into account the upcoming Olympics, it is interesting to know the precise parameters
    of the feed. If anybody have DVB-S2x, 16/32APSK or NS3/NS4 devices, please check this feed.
    120cm offset motorized dish, 22W - 103E arc, Inverto Black Ultra (Ku-band) + DreamTech GTP-D22 Twin (C-band circular) + Triax TKT001 (Ka-band B)
    47.5N 42.2E, Russia
  • Sorry Tempo, I could not test it faster, my actuator was freezed.
    12560 H (at the moment) not found.
    12708 H not found with the TBS6908, but different result with Crazyscan and IQMonitor.
  • Hallo tempo,
    sendete 12560 H zu bestimmten Zeiten?
    Heute habe ich mit der TBS6903x die gleichen Transponder bekommen, mit wenigen Zehntel Unterschied bei den dB.
    Hello tempo,
    sent 12560 H at certain times?
    Today I got the same transponder with the TBS6903x, with a few tenths of a difference in dB.
    Привет темп,
    отправлял 12560 H в определенное время?
    Сегодня получил такой же транспондер с TBS6903x, с разницей в несколько десятых долей дБ.
    Hi tempo and femi,
    I can see this peak in spectrum, centered at 12560 H with my TBS 6903. A scan (and manual searches with different SR) on TBS 6903X without any results (in S2X).
    Genau das gleiche bei mir , ich sehe ganz gut auf dem Spectrum diese "hügel" davon kann ich aber nichts bekommen , auch mit einem DVB-S2X Receiver
    Exactly the same with me, I see quite well on the Spectrum these "hills" of it I can get but nothing, even with a DVB-S2X Receiver
    Точно так же и у меня, я вижу эти "холмы" довольно хорошо на спектре, но я не могу ничего получить от них, даже с DVB-S2X приемником.
  • Hi femi, qwer and stephan94,
    Hello tempo,
    Yes, this TP (probably testing of a feed) is active few hours per day.
    Seems to me, there is another one new NS3/4 feed (maybe for upcoming Olympics, then the same primary feed should be tested at the same time at 100.5e in C-band).
    So, only Feedsat could check this and confirm or not confirm.
    47.5N 42.2E, Russia
  • I tested (Trp 12560 H) with the new Crazyscan 170, there was changes for the 6902SE cards, but still no IQScan.
