12681 H 3250 3/4 QPSK DVB-S2
07.0°E Eutelsat 7B/7C
10970 H 4937 3/4 8PSK DVB-S2
For fans,
it's FTA10961 H 9875 3/4 Super Rugby
11075 V,60000,2/3,S2/16APSK-LK Enc
It was active few minutes ago with 2 programs, one EBU promo and a 2nd with ID
C02Gvs1 UNL Promos
in 8PSK
will probably back again within the minutes or later...
12515 V,7190,3/4,8PSK-Eco vs Fra(rugby)
Some feed is active at the moment, taking the whole transponder with central frequency 12560 H, but can't be locked. The SR could be 35000 ks/s.
This is the second test of this feed, the first was two days ago, at Sunday January 9.
Taking into account the upcoming Olympics, it is interesting to know the precise parameters
of the feed. If anybody have DVB-S2x, 16/32APSK or NS3/NS4 devices, please check this feed.
Hallo tempo,
sendete 12560 H zu bestimmten Zeiten?
Heute habe ich mit der TBS6903x die gleichen Transponder bekommen, mit wenigen Zehntel Unterschied bei den dB.
Hello tempo,
sent 12560 H at certain times?
Today I got the same transponder with the TBS6903x, with a few tenths of a difference in dB.
Привет темп,
отправлял 12560 H в определенное время?
Сегодня получил такой же транспондер с TBS6903x, с разницей в несколько десятых долей дБ.
Genau das gleiche bei mir , ich sehe ganz gut auf dem Spectrum diese "hügel" davon kann ich aber nichts bekommen , auch mit einem DVB-S2X Receiver
Exactly the same with me, I see quite well on the Spectrum these "hills" of it I can get but nothing, even with a DVB-S2X Receiver
Точно так же и у меня, я вижу эти "холмы" довольно хорошо на спектре, но я не могу ничего получить от них, даже с DVB-S2X приемником.
Hello tempo,
Yes, this TP (probably testing of a feed) is active few hours per day.
Seems to me, there is another one new NS3/4 feed (maybe for upcoming Olympics, then the same primary feed should be tested at the same time at 100.5e in C-band).
So, only Feedsat could check this and confirm or not confirm. -
