Just my scan on 1.2m mot. dish.
07.0°E Eutelsat 7B
Just my scan on 1.2m mot. dish.Nothing changed end of semptember...
Bad situation at this time from this position.
not my catch, elchromo (with 1.8m) yesterday on DXtv:
21565 H 1100 2/3 DVB-S2 8PSK, ID: B6tv >>> only 2.4dB, unlocked of course with 1.2m
My poor scan right now... not all (5 frequencies) possible in one scan.
21565 H 1100 2/3 DVB-S2 8PSK, unlocked here (2.4dB)
21566 H 1110 2/3 DVB-S2 8PSK, unlocked here (4.8dB)
21568 H 1100 2/3 DVB-S2 8PSK, unlocked here (4.7dB)
21569 H 1100 2/3 DVB-S2 8PSK, unlocked here (6.1dB)
21571 H 2442 2/3 DVB-S, locked on 8.7dB -
Now possible...
21569 H 1100 2/3 DVB-S2 8PSK21571 H also of course.
I have B6 TV just around lock
Original von Afreaka
I have B6 TV just around lockGreat, Afreaka!
...4.1dB here (1.2m).
Hi!
My Signal with 1,8m laminas
Regards, elchromo
Original von elchromo
Hi!My Signal with 1,8m laminas
Regards, elchromo
Thanks for sharing to us, elchromo - Danke!
Okay - nothing new here - but I have to change my LNB next and try another... 21565 H not possible here.
21565 H 1115 2/3 2S TV new SR? Im on minimum ,but SR is found still the same .
Okay - nothing new here - but I have to change my LNB next and try another... 21565 H not possible here.Another scan with same setup...
No changes.
/edit: Okay, "locked" 21567 H some minutes later...
/Oops... in my last scan 21565 H appeared...
This is my signal for the 4 transponders, which are so close together and with same mode. B6TV just around lock, causing high BER...runs better on my Openbox than on TBS
Hallo
Diese Frequenz ist anscheinend mit einer 120cm Antenne sehr schwierig zu knacken.
Bei mir war es sehr schwer.
Blindscan von allen Gerät haben es nicht gefunden .
Nur mit Manuel Eingabe war es einigermassen möglich
TBS6983 ab und zu stehendes Bilder sonst nicht anders
Openbox Sx6 schon schwer zu locken ( Name ist sogar nicht gefunden) danach sehr lang nur schwarze Bildschirm und ab und zu wie bei dem TBS ein stehendes Bild.
Moi4K auch per Hand muss man alles eingeben , bei ihm es es irgendwo eine Art von bewegendes Bild aber sehr schlecht Qualität.
Ich habe alles versucht mein Empfang zu verbessern , über 6,5 dB bin ich nicht gegangenThis frequency is apparently very difficult to crack with a 120cm antenna.
It was very difficult for me.
Blindscan of all device did not find it.
Only with Manuel input it was reasonably possible
TBS6983 now and then standing pictures otherwise
Openbox Sx6 already difficult to lock (name is not even found) then very long only black screen and now and then as the TBS a standing picture.
Moi4K also by hand you have to enter everything, with him it somewhere there is a kind of moving picture but very poor quality.
I tried everything to improve my reception, I did not go above 6.5 dB7° Ost 21565 H 1100 8PSK DVB S2
B6TV -
Nothing special for most of you, but my first success: CS streaming with TSReader...
(here: Muvi package on 21751 H)
My current scan (1,2m).
21565 H not lockable for me (3,8dB).
Active feed on 21546 H 7200. -
Just my signal (not in one scan).
Just a look on this position with 2,2m, using (wrong) Invacom ADF_10 feed and MCL-KP04 PLL LNB.
Hm, can´t get 21564 H and 21567 H in scan.
Just a current scan on this position on 1,8m. Nothing new appeared.
Hallo
Heute habe ich alle dicht nebeneinander Transponder problemlos mit IQM 2402 gefunden.
Alles ,wie immer, mit 1200 laminasToday I easily found all the transponders close to each other with IQM 2402.
Everything, as always, with 1200 laminasBleib gesund
FYI: Changed toppic name (Eutelsat 7A before).
