07.0°E Eutelsat 7B
  • The MUVI-package on 21750 H is off since about 2 days :35:
    11 fix dishes 78cm-240cm
    Ka-Band: 7E 125cm , 16E 150cm, 2 * Inverto KaKu
    C-Band: 10E: 240cm PFA - 26E: 230cm mesh - 3E: 180cm PFA - 8W: 167cm PFA LNB: 4 * Kaonsat 13K
    KU-Band: 78-150cm, multifeed
    RX: Openbox SX4/SX9, TM5402, TBS 5927, Edision Primo IP S2
    Just another scan after a long time (1.8m and MCL-KP04).
    Nothing new appeared.
    C-band: 55.5°West-68.5°East ORBITRON O-16 (4,9m) / X-band: 17.8°W-60.2°E KATHREIN CAS 120 (1,2m) / Ku-band: 61.0°West-80.0°East KATHREIN CAS 23 (2,2m)
    Ka-band A/B/C/D: 30.0°W-75.0°E KATHREIN CAS 018 (1,8m) / Ka-band band A 2x KATHREIN CAS 120 fix on 19.2°E and 42.0°E
    C-band LNBs: Kaonsat, C-Panorama 13K, Norsat 8000RI C-DRO, BrasilSat LNBF AP30 PLL / X-band LNB: Norsat X1000HAF / Ku-band LNB: Invacom SNF-031, Inverto Single Flange / Ka-Band LNBs: Inverto Twin WHITE Ka Circular Dual Polarity LNB (flange), Inverto IDLK-SINL20-KAKU-OPP,MCL-KP04, Norsat 9000HX-O3B-BN, Orbital LNB1825F-1000D-WF55
    Feeds: Invacom ADF_10 + 2 rings, XMW Ka-band Feed FD9000K / Waveguide Polariser: AV-COMM / Tuner: TBS 6925, TBS 6903, TBS 6903X, TBS 6522
  • QTV from Gambia on lyngsat/flysat left...but it´s still on! (1.2m Gibby)
    Thank you Afreaka for your report.
    Nothing new in linear horizontal scan.
  • Not too sure if i have seen this one documented before on 7East
    /edit by qwer: merged in this toppic
    Just another scan in this range (two in manual) - nothing new appeared.
    Only one in manual in april scan - but no other changes here. :26.
    Nicht viel geändert .
    Bei mir kann ich die 21567 nicht kriegen
    Not much changed.
    I can't get the 21567
    Ein Scan von Heute ,
    es gibt für mich ein paar neuen Transponder
    21402 und 21609 , vielleicht beacon ( 21402)
    aber 21609 ?
    A scan from today ,
    there are a couple of new transponders for me
    21402 and 21609 , maybe beacon ( 21402 )
    but 21609 ?
    Just my three locks with poor signal on my setup.
    FYI: 21402 with "ring" constellation and 21609 with QPSK constellation, according CrazyScan.
    Just an update after a long time... nothing new according FS.
    A scan from today ,
    but 21609 ?
    A bit late but, yes, 21402 is a plain carrier and probably a beacon
    RE: Ka-band D beacons
    Today's scan using Gilat LNB on 1.2m offset
    qwer Are any of the unlocked ones S2X?
    Here's a fairly high resolution (>4k wide) spectrum where the transponder noise is very clear. Many of the signals between 21534 and 21595 are time variant.
  • Just my early autumn scan here - some changes since last scans here.
    Not my catches:
    21595 H 1100 3/4 DVB-S2 QPSK, URHC (Benin) - Jonali on LyngSat 04.09.2022
    21619 H 2200 2/3 DVB-S2 8PSK, 2S TV (Senegal) - S Evans Jamie A on LyngSat 21.08.2022
    PS: No signal here on 21639 H, QTV Gambia.
    Left: 21626 H, New World TV package and 21607 H, 2S TV (changed to 21619 H).
