Scan of the day: DATA (MIS & Transport)
Beacon: 12200 H
Beacon: 12200 H
11105 V,1000,1/4,Dvb-S2,ACM,GS,Multi(0)-Vpid-256,Apid-257.
Hard to know what tv station is, but it certainly is a Russian program, because there is talk in Russian.
Hi Feedsat,
Thanks for SES-6's RF.Here is what I could lock with my antenna on this satellite that I've scanned today.I've never found two transponders: 11081 and 11086 although I scanned several times.Instead I came across 11083 V,7735,1/4 also in Stream Continous.It looks like is an update of the symbol rate of the nearby transponders.I do not know which one,because there are no two trps.mentioned above on my RF.
Same situation here now as sattesco wrote one post earlier.
PS: I can´t lock 11095 V 1034 DVB-S2.
Hi Qwer,
Thank you that you have checked this satellite.Till Feedsat will give us the answer,I'll post list with transponders found by Crazyscan.
I do not think that it matters,but I mention that I used Inverto Black Ultra with scalar rings, who gave me the best results when scanning.
Here's how it looks LNB IBU for offset dish with combination of a scalar rings.
Nothing on 11095 V, even in Hard lock
Thank you both and no luck here with 11095 V too, Feedsat.
But as I can see, satesco get 11095 V today. So I added it on the list with first finding user.
No changes with vertikal polarisation.
New (in horizontal polarisation):
11102 H 1000 DVB-S2 Single
11103 H 1000 DVB-S2
11107 H 4530 DVB-S2
Nice one Qwer !
Weak signals...
First I was a little bit shy, but now it´s sure, there are some more carriers in horizontal polarity, using nearly same SR as on vertical polarity (see next post too).
10995 H 44296 DVB-S2
11155 H 22495 DVB-S2 (same parameter as on vertical posarisation, but different constellation diagram, see next post)
PS: 11050 H, Data
Look on vertical spectrum.
No changes.
Constellation monitoring on 10995 V and 11155 V (file 2 and 3).
I always thought this was the result of my cross polarization settings for this position and I've never try a scan
ZitatOriginal von Feedsat
I always thought this was the result of my cross polarization settings for this position ad I've never try a scan
Me too...
11107 H has left I think (or 2 weak...)
Hi Feedsat,
11007 H still there, but not found in BS right now. Weak signal here.
Scan of the day linear vertical.
Changing SR:
11083 V 11070 DVB-S2
Thanks, got it now but as you said, not in BS mode
11112 V 1700
11091 V,1700,3/4,Dvb-S2/8PSK,ACM,GS,Single-New symbol rate or new GS?
Yes Satesco , 11091 V is new (Moved from 11112 V which is off now offline ?)
