16.0°E Eutelsat 16A
    Just for stats...
    Nothing new.
  • 16°E
    12627,V,2450,56,8PSK Can anyone check this out?
    Borovo Naselje Croatia
    Original von milan58
    There is already a third day as the signal is weak, maybe the PLS code?
    12574/V/6500 2/3 8PSK(DVBS2)
    without PLS, maybe dual mode
    Code
    tune to freq 12575000, symbol rate 0, pls no 0
    blind tp 0, 12574004, 6500
    blind tp 1, 12574070, 4600
    blind scan freq = 12574004, symbol rate = 6500000
    file= nim.c,lock
    Edited 2 times, last by EnoSat ().
    Thanks milan58:74:
    12574 V,now is 6000,fec unknown?
    I can not lock this signal,so please whoever can to tell what contains this transponder?
    Regards
    Thanks milan58:74:
    Regards
    not PLS
  • Tomek22 thanks for your sincere response.Sky Radio TNZ and Veronica TNZ at playback on VLC player have no tons,and unlike when recording content, the footage is correctly reproduced in Windows Media Player.This applies to CrezyScan and IQMonitor.
    As far as this frequency is concerned, there is a signal variation in me the level is constant at 63% while the quality varies from 30% to 100%,in dB with 15dB falling to 3dB,but I guess it's close to Radio 10 TNZ, Radio 538 TNZ.
  • 12627,V,2450,56,8PSK
    I have now discovered that this is the frequency of the feed
    :46:
    New frequency 11070.070,H,375,35,8PSK-Sky Radio TNZ,Veronica TNZ
    Let's go girls and boys who can lock this signal?
    I´m late, I know... :46:
    Just my manual scan here - probably I forgot one? :79:
    /edit: one more...
  • 11069.965 H,274,1/2-Slam! Main-new symbol rate,
    11070.351 H,274,1/2-100%NL MAIN-new symbol rate
  • the only thing I can see from here 11016H1500 :83:
    1=10803,H,30000,34,2 ;-44 dBm, 0.9 dB; 18:40 10/10/2018 No Locked
    2=10886,H,30000,35,2 ;-44 dBm, 0.5 dB; 18:40 10/10/2018 No Locked
    3=10976,H,24110,34,2 ;-46 dBm, -0.5 dB; 18:40 10/10/2018 No Locked
    4=11002,H,8332,56,2 ;-46 dBm, -0.1 dB; 18:40 10/10/2018 No Locked
    5=11016,H,1499,34,1 ;-47 dBm, 4.4 dB; 18:40 10/10/2018
    6=11041,H,4166,56,2 ;-49 dBm, 0.4 dB; 18:40 10/10/2018 No Locked
    7=11512,V,29950,23,2 ;-55 dBm, 0.4 dB; 18:40 10/10/2018 No Locked
    8=11595,V,30000,56,2 ;-55 dBm, -0.9 dB; 18:40 10/10/2018 No Locked
    9=12602,H,30000,23,2 ;-52 dBm, 1.2 dB; 18:40 10/10/2018 No Locked
    most of them I think from "E16A Sub-Sahara Africa" Listed in FS by Afreaka & Matie Yendu :73:
  • Yes, I can receive the Sub-Sahara-beam in Agadez, south of you, with 100cm without problems, even if the signal on some tps is not very high (sorry, I have no dB). Interesting, that you have lock on 11016 H (E-Télé).
    11 fix dishes 78cm-240cm
    Ka-Band: 7E 125cm , 16E 150cm, 2 * Inverto KaKu
    C-Band: 10E: 240cm PFA - 26E: 230cm mesh - 3E: 180cm PFA - 8W: 167cm PFA LNB: 4 * Kaonsat 13K
    KU-Band: 78-150cm, multifeed
    RX: Openbox SX4/SX9, TM5402, TBS 5927, Edision Primo IP S2
    Edited once, last by Afreaka ().
    Original von Afreaka
    very good Afreaka :71:
    may be the Low SR 1500 which makes the signal locked :88:
    I see some thing like that before with NigComSat-1R @ 42.5° East
    12539H5000 :
    /edit by qwer: LINKS disappeared (01.08.2020).
    Ku: 1.80m OS (Testing.....)
    C: 1.80m PF
    C-Band LNB:Panorama ER861
    C-extended LNB: Bwei 5750Mhz
  • 11071.127 H,176,3/4-BNR_AMS(new symbol rate)
    Original von flie
    the only thing I can see from here 11016H1500 :73:
    11016H SR changed to 2083 .... No locked :83:
    C: 1.80m PF
