53.0°E Express-AM6 <S1/S2>
  • Yes, today WATAN was moved from 11665H to 11655H
  • Satsearcher on Sats UK noticed some changes. When I first looked there were 2 narrow TPs either side of the data on 11660. The signal below those look quite poor and would not lock easily but it was the Watan group.
    It then changed to this:
    With the TV below the data as here (Ignore frequency on constellation plot):
    I can't lock the signal on 11668H using CS on a TBS6903
    1.8m PF, Polar mount with SMW Q-PLL type C or R, Precision/Elite feed
  • I tried Minitiourner on 11668 and I could get a partial lock with 2000ks/s at an MER of 8dB. However, CS would not lock with BS disabled using 2000ks. Maybe IQ monitor can do better.
  • I can't work this out at all. Things changed since last night. Now I can only lock the 10000ks data signal which is at 4.7dB but looks like there is something underneath it.
    Here's this morning's spectrum with Marker 1 11668 2000ks
    marker 2 11652 10000ks with a poor shape
    marker 3 11661 which looks similar to marker 1 i.e. 2000ks.
    compare to yesterday evening when Watan was good at 7.3dB SNR despite having a poor spectrum shape:
    <edit> Now Watan is in the clear as the data is off. The 2 narrow signals are still there.
  • My CS results... getting both in one scan... 11652 H 10000 1/2 DVB-S2 QPSK (data) not lockable here.
    Maybe if I used a bigger antenna, I could lock 11651 H(I'd like to hope so), but now I use a 1.10m one. Even so, the antenna sees the new mux.
    Maybe at another time it should be tried.
    Thanks, qwer :3:
  • ... for a short time...11652 H 10000 was lockable with big signal (+11.0dB over LM) and no chance of signal on 11650 H 8000... :26.
  • 11664 H 1/2 10500
    Laminas AS-1500 + Jaeger SMR 1224 HH Mount (80E - 45W)
    Inverto Black Ultra LNB
    U2C Denys H.265
    PC card TBS 5922
  • was ich heute früh empfangen konnte
    My CS result from today
  • Zum Vergleich mit 2.2m...
  • I think Watan is now on 11660H and sitting on top of the 2000ks signal at 11661 with another narrow signal, on 11665, which extends the apparent bandwidth of Watan's 10500ks. Watan is around 7dB SNR at the moment and has a similar signal strength to that which it had when it was in the clear at 13dB.
    from 6/6/24:
    and today:
