53.0°E Express-AM6 <S1/S2>
  • I re-pasted the map with my location, I'm a bit far from the first signal line.:3:
    2x T90 + diseq 1\16
    Channel Master 180cm / LR / VH / Ku-band/Sweden/
    Channel Master 2,4m (Poland) Kołnierz podwójny Inverto biały ultra/2xNEW C-band 5G :18:
  • 10992 H 3500 - SD_MPEG2 (Telekanal 78)
    Laminas AS-1500 + Jaeger SMR 1224 HH Mount (80E - 45W)
    Inverto Black Ultra LNB
    U2C Denys H.265
    PC card TBS 5922
  • Transporder already turned off:37:
    2x T90 + diseq 1\16
  • Hmmmm.........:28:my location is north-east and the signal is almost zero
    2x T90 + diseq 1\16
  • 10992 H,3500,3/4-Telekanal 78.ru. torrex12 on FlySat :3:
  • 11005 V, 2142,5/6,8 PSK -Shihab,
    11010 V, 2200,3/5,8PSK-1 Channel 8 Kurdish.
    Both programs are not new; they are reported on FlySat.
    Telekanal is active; no changes.
    As known for those who have tried to lock 10992 H,3500,3/4, even if it's in dvb-s, it's hard to catch in my area, but I think in others, that's why it's a permanent target for many rare "treasure" hunters.
    The signal seems to have been a little more generous today, although it's raining in the area.
  • 53.0E_12683 H,1000,1/2-Audio feed, I think, on Fixed beam #1
    I believe this audio feed is a kind of backup from a studio(TV)(?), which sometimes uses one audio track(Apid 256 1-ford), sometimes two(Apid 256/257 sprinter1).
  • 11005 H,1000,3/4-Rossiya24,
    10992 H,3500,3/4-Tele78.ru, locked again,
  • Guten Morgen
    kann jemand die neue Frequenz 11027 V 15285 T2MI empfangen? Leider ist das aus Nordbayern mit 1,80 nicht möglich.:88:
    Hello
    Can anyone receive the new frequency 11027 V 15285 T2MI? Unfortunately this is not possible from northern Bavaria with 1.80.:88:
  • Guten Morgen
    Hello
    Earlier, I found 11027 V, but now it has left the satellite.
    I failed to lock it manually; only 10713 V and 10729 V were locked. :3:
