53.0°E Express-AM6 <S1/S2>
  • I re-pasted the map with my location, I'm a bit far from the first signal line.:3:
    2x T90 + diseq 1\16
    Channel Master 180cm / LR / VH / Ku-band/Sweden/
    Channel Master 2,4m (Poland) Converters running automatically on the rail / 2xNEW C-band 5G :18:
  • 10992 H 3500 - SD_MPEG2 (Telekanal 78)
    Laminas AS-1500 + Jaeger SMR 1224 HH Mount (80E - 45W)
    Inverto Black Ultra LNB
    U2C Denys H.265
    PC card TBS 5922
  • Transporder already turned off:37:
    2x T90 + diseq 1\16
  • Hmmmm.........:28:my location is north-east and the signal is almost zero
    2x T90 + diseq 1\16
  • 10992 H,3500,3/4-Telekanal 78.ru. torrex12 on FlySat :3:
  • 11005 V, 2142,5/6,8 PSK -Shihab,
    11010 V, 2200,3/5,8PSK-1 Channel 8 Kurdish.
    Both programs are not new; they are reported on FlySat.
    Telekanal is active; no changes.
    As known for those who have tried to lock 10992 H,3500,3/4, even if it's in dvb-s, it's hard to catch in my area, but I think in others, that's why it's a permanent target for many rare "treasure" hunters.
    The signal seems to have been a little more generous today, although it's raining in the area.
  • Today, my signal is slightly over 11db:70:
    2x T90 + diseq 1\16
  • 53.0E_12683 H,1000,1/2-Audio feed, I think, on Fixed beam #1
    I believe this audio feed is a kind of backup from a studio(TV)(?), which sometimes uses one audio track(Apid 256 1-ford), sometimes two(Apid 256/257 sprinter1).
  • 11005 H,1000,3/4-Rossiya24,
    10992 H,3500,3/4-Tele78.ru, locked again,
  • Guten Morgen
    kann jemand die neue Frequenz 11027 V 15285 T2MI empfangen? Leider ist das aus Nordbayern mit 1,80 nicht möglich.:88:
    Hello
    Can anyone receive the new frequency 11027 V 15285 T2MI? Unfortunately this is not possible from northern Bavaria with 1.80.:88:
  • Guten Morgen
    Hello
    Earlier, I found 11027 V, but now it has left the satellite.
    I failed to lock it manually; only 10713 V and 10729 V were locked. :3:
  • After several months, 78.ru on 10992 H,3500 reappeared with great difficulty on the "radar."
    Today, the signal is better on 10992 H. I tried using the 6909x card to tune it with the VMA StreamReader and almost succeeded with VMA. I was just a little short of getting it to run smoothly.
    On the other hand, the 6983 card, and even the 6589, handled the signal better at the limit.
    Instead, Guberniya TV on 10974 H is received all the time in my area.
  • New scan 3m Parsat.
    Helyszín: Nádudvar, magyar.
    2.4.x2.7.m Laminas.
    2,2 méteres fókusz.
    C, Ku sáv 95.0Kelet-55.5West.
