4555 L new SR 27865
PS: 4730 L 27500 is back
4555 L new SR 27865
Just my bad scan in circular left...
Just my complete circular scan after a long time.
I will check the updates (GS or TS, data) later...
Checked temporary GS streams for the list...
4523 L 15445, unlocked GS?
4555 L 40360 DVB-S2 (ACM), MIS 0, active VPID 256, APid 257
using:
QPSK 1/2
QPSK 2/3
QPSK 3/4
QPSK 4/5
QPSK 5/6
8PSK 3/5
16APSK 8/9
32APCK 3/4
4622 R 35765 DVB-S2 (ACM), MIS 0
using:
QPSK 1/2
QPSK 2/3
QPSK 3/4
QPSK 3/5
QPSK 4/5
16APSK 8/9
32APCK 3/4
PS: Other Locks in scan above are all data (TS) - nothing new.
Just another circular scan - please notice: opposite polarities!
Not lockable for me:
4541 R 3815 3/4 DVB-S2 8PSK (probably TS, data)
...using AV-COMM and Brasilsat LNB - not correct aligned - wrong polarity here...
Just another circular scan - correct polarisation at this time.
No changes.
Just another scan here - nothing new appeared.
Still not lockable: 4523 L 15444
PS: Possible today: 4541 R 3515 3/4 DVB-S2 8PSK (TS, data)
/edit: IQmonitor and TBS 6903X.
Just some more "IDs"... nothing else changed.
Nothing new in August ´20.
October scan - nothing changed.
UEFA NATIONS LEAGUE via SKY UK on 4679 R
4555 L 40360 and VPid 211/APid 221
Nothing else new here.
/edit: Active again, VPid 256/APid 257 on 4679 R 33000.
Scan. New parameter: 4548 L 32290, GS
PS: 4679 R 33000 is the "last GS" from this polarisation, others are TS.
Left: 4622 R and 4764 R
At least I confirm that this C_ext Bwei LNB works ...
...I still need a C-feed horn for single polarity, my signal is very low !!! because I tested with home made feed horn !
Nothing new appeared - but 5 have left...
My Scan on 180CM and Solid C-BAND LNB EXTNDED
Unfortunately Bad signal because ,I use liner-scan with only one polarity
to increase signal must use "polo polariser" like what moonbase did here :
https://www.satellites.co.uk/f…ended.165728/post-1063419
https://www.avcomm.com.au/shop…ircular-polarisation-kit/
seems longue way for me to get better signal ,until then I will poste results any way ;of course if moderator agree
only one TP is locked in C-extended 4679,R,16140 with 2.4 dB !
and 02 no -locked: 4663,R,3040 & 4762,R,3045 (need to convert polarity to lock them)
the good thing with this chinese lnb ; that you can see both C-band and C-band-extended in the same spectrum
Sure - go ahead flie !
