30.5°E Arabsat-5A
    4555 L new SR 27865
    PS: 4730 L 27500 is back
    Just my bad scan in circular left... :91:
    Just my complete circular scan after a long time.
    I will check the updates (GS or TS, data) later... :72:
    Checked temporary GS streams for the list...
    4523 L 15445, unlocked GS?
    4555 L 40360 DVB-S2 (ACM), MIS 0, active VPID 256, APid 257
    using:
    QPSK 1/2
    QPSK 2/3
    QPSK 3/4
    QPSK 4/5
    QPSK 5/6
    8PSK 3/5
    16APSK 8/9
    32APCK 3/4
    4622 R 35765 DVB-S2 (ACM), MIS 0
    using:
    QPSK 1/2
    QPSK 2/3
    QPSK 3/4
    QPSK 3/5
    QPSK 4/5
    16APSK 8/9
    32APCK 3/4
    PS: Other Locks in scan above are all data (TS) - nothing new.
    Just another circular scan - please notice: opposite polarities!
    Not lockable for me:
    4541 R 3815 3/4 DVB-S2 8PSK (probably TS, data)
    ...using AV-COMM and Brasilsat LNB - not correct aligned - wrong polarity here...
    Just another circular scan - correct polarisation at this time.
    No changes.
    Just another scan here - nothing new appeared.
    Still not lockable: 4523 L 15444
    PS: Possible today: 4541 R 3515 3/4 DVB-S2 8PSK (TS, data)
    /edit: IQmonitor and TBS 6903X.
    Just some more "IDs"... nothing else changed.
    Nothing new in August ´20.
    October scan - nothing changed.
    UEFA NATIONS LEAGUE via SKY UK on 4679 R
    4555 L 40360 and VPid 211/APid 221
    Nothing else new here.
    /edit: Active again, VPid 256/APid 257 on 4679 R 33000.
    Scan. New parameter: 4548 L 32290, GS
    PS: 4679 R 33000 is the "last GS" from this polarisation, others are TS.
    Left: 4622 R and 4764 R
  • At least I confirm that this C_ext Bwei LNB works ...:73:
    ...I still need a C-feed horn for single polarity, my signal is very low !!! because I tested with home made feed horn !:26.
    Nothing new appeared - but 5 have left...
  • My Scan on 180CM and Solid C-BAND LNB EXTNDED
  • Unfortunately Bad signal because ,I use liner-scan with only one polarity :88:
    to increase signal must use "polo polariser" like what moonbase:70: did here ::25:
    https://www.satellites.co.uk/f…ended.165728/post-1063419
    https://www.avcomm.com.au/shop…ircular-polarisation-kit/
    seems longue way for me to get better signal :37:,until then I will poste results any way ;of course if moderator agree :70:
    only one TP is locked in C-extended 4679,R,16140 with 2.4 dB !
    and 02 no -locked: 4663,R,3040 & 4762,R,3045 (need to convert polarity to lock them)
    the good thing with this chinese lnb ; that you can see both C-band and C-band-extended in the same spectrum :73:
    Sure - go ahead flie !
    Just my 2022-scan - using BrasilSat LNBF AP30 PLL and AV-COMM. :3:
    As we can see in flie scan - spectrum has changed here.
    Still on:
    4679 R 16140
    New GS appeared - others TS:
    4741 L 13333
    4764 L 2681
  • New here:
    4677 R 9164
    PS: 4684 L 24280 can be locked in S2/S2X, using TBS 6903X.
