Scanned today Yamal 402 with EBS.
54.9°E Yamal-402
oh, I miss some tp like 10962, 10967, 11265 and so on..........
have you catchted specially tp? -
In terms of reception,the most interesting transponders are those with low symbol rate,there are many with generic stream and the signal is fluctuating.Without exaggerating,I'd say it's a little performance to get those trps when you have a relatively small dish.This is why those on the spot Russia doesn't catch.But for us,dxers,special trps are those that are at the limit.Each transponder snatched from a distant spot is a performance in itself.In fact transponders are not special,but satellites whose spot do not come into our area.Many users looking for programs,we're looking for signal,isn't it?
correctly, thanks.
MATCH TV 12722 V 3254 3/4 DVB-S BISS
Laminas AS 180
Can someone check.
1=12682,H,29990,34,8PSK
2=12718,H,29995,34,8PSK
3=12715,V,12223,23,qpsk-feed -
Original von milan58
Can someone check.
3=12715,V,12223,23,qpsk-feed12715 V is not feed but a tv package from Gazprom,and 12682 H and 12718 H I couldn't lock so far.
Scan of the day with EBS Pro
I have a problem with 11345 V 30000 8PSK FEC 3/4 or 2/3?
with signal 7,6dB I'm aible zu begin a search.
with FEC 3/4 I need 8,3dB to begin a search.
thanks and regards -
Original von Kleinraisting
I have a problem with 11345 V 30000 8PSK FEC 3/4 or 2/3?with signal 7,6dB I'm aible zu begin a search.
thanks and regardsHi Kleinraisting,
FEC is 3/4 on 11345 V.
PS: Without Skew Control atm.
danke, qwer!
schöne Grüße
Scan of the day with TBS5927 Tuner USB
My full BS night time from my place. North West Italy, 4.2Mt dish. Ver hard for the Russian Beam
This frequency
It appeared in the search Blind scan
But then added no reference
Please testedXML
Alles anzeigen<?xml version="1.0" encoding="iso-8859-1"?> <!-- File created on Monday, 20 of March 2017, 11:16:29 using vuultimo receiver running Enigma2 image, version 2017-03-16-(detached from d5a8acf), image Satdreamgr-openpli-gst1 4, with the Blind scan plugin Search parameters: Tuner A: Vuplus DVB-S NIM(AVL2108) (DVB-S2) Satellite: 54.9E G-Sat 8 & Yamal 402 Start frequency: 10700MHz Stop frequency: 12750MHz Polarization: vertical and horizontal Lower symbol rate: 1000 Upper symbol rate: 45000 Only save unknown tranponders: no Filter out adjacent satellites: no --> <satellites> <sat name="54.9E G-Sat 8 & Yamal 402" flags="0" position="549"> <transponder frequency="11973907" symbol_rate="27499094" polarization="0" fec_inner="3" system="1" modulation="2"/> </sat> </satellites>
I think, this frequency range for "11973 H" is not at this position.
My scan in upper band.
I think, this frequency range for "11973 H" is not at this position.My scan in upper band.
Thank you qwer
And sorry for the inconvenience -
12229 H,3300,?
I found this frequency at 54.9E and I'm not sure if it's from Yamal 402,Gsat-18-55.4E and GSat-8-55.8E?
I would ask you to check to determine where this signal comes from?Edited:I found out now where the signal came from Türkmenälem-52.0E Strong signal in my area that it goes to close positions
11001 H 1100 5/6 QPSK2 no lock
New radiopack,
12531 H 2500 5/6 QPSK2
Provider Name: CONNECTO.TV
Original von marval450
11001 H 1100 5/6 QPSK2 no lockMy signal.
