11145 V,1735,3/4,DvbS/QPSK-Data
53.0°E Express-AM6
11021 H,5000,1/2,Dvb-S2/QPSK,ACM,new Data-AOL
11154 V 4740 3/4 DVBS
11018 H,3000,3/4,Dvb-S2/QPSK,ACM,Single-new Data AOL
New, no services yet. Will be data or video soon?
I have a narrow peak at 11649 H, small dB readings when trying symb. between 2000 and 2500, anyone can lock this?
unfortunately :
11345 V 11200 3/4 Data???
Never saw data here,still only empty carrier.
Original von marval450
Look on FlySat
12594 V,27500,2/3,Dvb-S/QPSK-Data(new)
I found 2 data? TPs at 53E, but I doubt it is Express.
Express has frequency range from 10950 .
Checked few times with 2 dishes ,it is directly 53E .
Edit: same TPs in vertical ,so it can be circular...
AM6 has 10.7...10.95 GHz as well, fixed beam 1 (to Russia)!
http://frequencyplansatellites.altervista.org/Express/Express_AM6.pdf
Edit: circular Ka band uplinks, so perhaps indeed, downlink is circular as well? -
Ups ,next time I have to look through all site.
I will check those TPs later with plate in, when AMC 14 will be around equator .
Checked with plate in , worse results than linear.
Thanks for testing marval450!
So the frequency plan is correct. -
We have next opposite TPs here, 11262 H+V 28000 5/6 DVBS, maybe data in the future, empty carriers atm.
I found 2 data? TPs at 53E, but I doubt it is Express.Express has frequency range from 10950 .
Thanks@Marval450,you're right,those transponders are on the polarity circular.On the vertical signal is stronger,but despite of it couldn't get it lock.I think that must be at least 10.30>11 dB.Of course I used linear polarity lnb.
11262 is empty, like you said. -
Not circular, I wrote earlier: checked with plate in , worse results than linear.
Strange,each check the polarity with the different methods,you,with plate,I, using both polarities.Unfortunately that I can not use now the lnb circular at 53E to figure out what is the truth.Until proven otherwise,I think it is circular?!,because the signal is on both polarities,as see below.The same signal is on 11262 V.
And yet it seems odd that the Russians use circular and linear at the same position.The fact that the first transponders moved from 54.9E at this position is a proof they will use linear at 53.0E?! -
what??? You are using both polarities? You are kidding.
Im not idiot I know what Im doing.
MY METHOD ???It is nothing new, what you think is in circular LNB?
Btw. circular LNB is for kids, not real DXers.And with this "method" I used to receive 56E- Bonum,,Direct TV Express AT1 East ,also Nimiqs, AMC 14.
Adding some pics, those TPs are LINEAR ,that is the fact. howgh, good night.
