...one more with high SR in lower band, but very weak signal, unlocked:
20354 L 27900 2/3 DVB-S2 QPSK
/edit: 20671 L 18210 2/3 DVB-S2 QPSK
Some more temp. streams, not lockable with costellation monitoring (as Feedsat reprted earlier)...
21080 L 3100
21083 L 54200 (-10dB No Lock - fake?)
21086 L 1973
21086 L 6370 (-10dB "lock") >>> probably another DR stream?
21088 L 2968
21088 L 3845 (-10dB No lock)
21178 L 1673
21183 L 2174 (-10dB "lock")
21184 L 4065
...to be continued.
SORRY for my "summer list break", but I´m still too lazy to start a new update...
So a little list here in forum...
Deeper scan range 21,05 to 21,2 GHz (TBS 6983) and including all catches in this toppic (thanks to Feedsat ).
These are locked with CS (most of them without constellation monitoring):
21061 L 1168 (Feedsat >>>constellatiom monitoring)
21078 L 1975
21080 L 3100
21083 L 3950
21085 L 3108/4065
21086 L 1975
21091 L 2600 (Feedsat >>>constellatiom monitoring)
21092 L 1580 (Feedsat >>>constellatiom monitoring)
21178 L 1675
21179 L 3100
21180 L 1760
21181 L 1820 (Feedsat >>>constellatiom monitoring)
21183 L 5120
21184 L 4065
21185 L 1975
21186 L 1975/3845
[21187 L 2970 (qwer >>>constellatiom monitoring: Transportstream)]
21189 L 4045
21191 L 1975
These are with CS (-10dB "lock"):
21063 L 3950
21086 L 6370 (probably another DR stream?)
21090 L 4045
21178 L 1975
21183 L 2175
These are are with CS (-10dB "no-lock"):
21083 L 54200 (probably fake?)
21088 L 3465/3845
21181 L 2100
21182 L 2100
PS: New findings in attached file. /edit: some more...
Thanks to dreamsat, yesterday on DXtv!
Inverto IDLK-SINL20-KAKU-OPP reaches spectrum down to 20,5GHz with modified CrazyScan Version 1.0.2.146.
Here my linear scan (without waveguide) from this position with 1,2m.
Strong signal on DR1 with Inverto IDLK-SINL20-KAKU-OPP, even without waveguide (1.2m).
I will test it next with waveguide, when weather is better here...
My first test with handmade waveguide at this time.
/edit: signal going up (half hour later)...
13.0dB with 1,2m atm. on DR1.
Just temporary streams - some reported earlier:
21081 L 3100
21180 L 3100
21185 L 3250
21186 L 1975
21188 L 2970
21190 L 4045
Tried today with 115cm, only fr.I can get is 21048 L .
Just another (circ. left) scan in upper band.
DR1 (21048 L) seems has left.
Not new, Dreamsat on FlySat 01.05.2019:
20898 L 3250 DVB-S2
new 20989 L 2970 ACM MIS 0
In band C today...
First test after some years on 2,2m, using (wrong) Invacom ADF_10 feed and Orbital LNB 1825F.
Probably new here:
20815 L 5935, DVB-S2 (ACM), MIS 1
Unlocked: 20671 L 18200
/edit: linear scan here.
Just another try with Inverto IDLK-SINL20-KAKU-OPP and CrazyScan Version 1.0.2.146 on 1,8m (Invacom feed), using plastic plate inside.
21083 L 3945 was active a short moment before. No new GS in this range.
There`s no sign of DR 1 (21049 LHCP) in eastern part of Slovakia. Is this channel still on, or we`re just out of coverage? But 3.7m dish has been used... marval has reported reception in Zilina (not that far away) with smaller dish. Can anybody check it out, please?
Anyway, here is scan made on 27.7.2020 by Peon.
It has left long time ago
In band C now. Circular left scan. Nothing new appeared.
Just for fun on New Years day...
Circular left spectrum in upper band C (including band D with MCL-KP04). Frequency 20718 L is not possible on this setup.
Up untill about an hour ago the signal was very low with me in Central UK and sometimes dropped to the noise floor but has slowly got stronger over the last 30 minutes .
Circular left scan in band C. New peaks appeared. New lockable in BS (left during manual scan): 21085 L 3250
