12.0°W WGS-3
  • ...one more with high SR in lower band, but very weak signal, unlocked:
    20354 L 27900 2/3 DVB-S2 QPSK
    /edit: 20671 L 18210 2/3 DVB-S2 QPSK
    Ku-band LNB: Invacom SNF-031
  • Some more temp. streams, not lockable with costellation monitoring (as Feedsat reprted earlier)...
    21080 L 3100
    21083 L 54200 (-10dB No Lock - fake?)
    21086 L 1973
    21086 L 6370 (-10dB "lock") >>> probably another DR stream?
    21088 L 2968
    21088 L 3845 (-10dB No lock)
    21178 L 1673
    21183 L 2174 (-10dB "lock")
    21184 L 4065
    ...to be continued.
  • SORRY for my "summer list break", but I´m still too lazy to start a new update... :79:
    So a little list here in forum... :83:
    Deeper scan range 21,05 to 21,2 GHz (TBS 6983) and including all catches in this toppic (thanks to Feedsat :73: ).
    These are locked with CS (most of them without constellation monitoring):
    21061 L 1168 (Feedsat >>>constellatiom monitoring)
    21078 L 1975
    21080 L 3100
    21083 L 3950
    21085 L 3108/4065
    21086 L 1975
    21091 L 2600 (Feedsat >>>constellatiom monitoring)
    21092 L 1580 (Feedsat >>>constellatiom monitoring)
    21178 L 1675
    21179 L 3100
    21180 L 1760
    21181 L 1820 (Feedsat >>>constellatiom monitoring)
    21183 L 5120
    21184 L 4065
    21185 L 1975
    21186 L 1975/3845
    [21187 L 2970 (qwer >>>constellatiom monitoring: Transportstream)]
    21189 L 4045
    21191 L 1975
    These are with CS (-10dB "lock"):
    21063 L 3950
    21086 L 6370 (probably another DR stream?)
    21090 L 4045
    21178 L 1975
    21183 L 2175
    These are are with CS (-10dB "no-lock"):
    21083 L 54200 (probably fake?)
    21088 L 3465/3845
    21181 L 2100
    21182 L 2100
    PS: New findings in attached file. /edit: some more...
  • Thanks to dreamsat, yesterday on DXtv! :74:
    Inverto IDLK-SINL20-KAKU-OPP reaches spectrum down to 20,5GHz with modified CrazyScan Version 1.0.2.146.
    Here my linear scan (without waveguide) from this position with 1,2m.
  • Strong signal on DR1 with Inverto IDLK-SINL20-KAKU-OPP, even without waveguide (1.2m).
    I will test it next with waveguide, when weather is better here...
  • My first test with handmade waveguide at this time.
    /edit: signal going up (half hour later)...
  • 13.0dB with 1,2m atm. on DR1.
  • Just temporary streams - some reported earlier:
    21081 L 3100
    21180 L 3100
    21185 L 3250
    21186 L 1975
    21188 L 2970
    21190 L 4045
  • Just another (circ. left) scan in upper band.
    DR1 (21048 L) seems has left.
    Not new, Dreamsat on FlySat 01.05.2019:
    20898 L 3250 DVB-S2
  • new 20989 L 2970 ACM MIS 0
    - Promax TV II+ - SMR1224EL x2
    - ASC1 X2 - RC2000C - EGIS - LNB Changer
    - 76.5°E <> 65°W
  • In band C today...
    First test after some years on 2,2m, using (wrong) Invacom ADF_10 feed and Orbital LNB 1825F.
    Probably new here:
    20815 L 5935, DVB-S2 (ACM), MIS 1
    Unlocked: 20671 L 18200
    /edit: linear scan here.
  • Just another try with Inverto IDLK-SINL20-KAKU-OPP and CrazyScan Version 1.0.2.146 on 1,8m (Invacom feed), using plastic plate inside.
    21083 L 3945 was active a short moment before. No new GS in this range.
  • There`s no sign of DR 1 (21049 LHCP) in eastern part of Slovakia. Is this channel still on, or we`re just out of coverage? But 3.7m dish has been used... marval has reported reception in Zilina (not that far away) with smaller dish. Can anybody check it out, please?
    Anyway, here is scan made on 27.7.2020 by Peon.
  • It has left long time ago
    - 76.5°E <> 65°W
