24.5°W Intelsat 905 (incl.)
  • I cannot lock these transpoders:11058 H,30000,3/4,16APSK and 11084 H,15000,4/5,16APSK.It seems to me that both are stream generic,but I'm not sure.Can you check them?
    Thanks
  • Hi qwer,Thanks for trying :72:
  • Here's my general check. Nothing new, I think
    Nothing lockable on some peaks via BS
  • 11495 H,65570,3/4,32APSK
    A high symbol rate that I can not lock,probably because of a weak signal,even if it is over 12dB.Maybe you have the luck to see this,it seems, a generic stream?Try and perhaps you can succeed.Anyway it's worth trying.Thanks :125:
  • qwer,
    Thanks a lot for trying.Is it a limit of Crazyscan or the signal needs to be stronger?Hopefully someone here will succeed.
    Regards :125:
    qwer,
    ...Hopefully someone here will succeed.
    Regards :125:
    11495 H,65570,4/5,Dvb-S2/16APSK,ACM,Single-new GS
    I'm "condemned" to lock it :71:, if I still found it.What this tells me,the "exceptional" parameters so far do not bring us any...exceptional content :82:
  • I exaggerate a little(and not too much),but I would say that this Intelsat at 24.5 W exists only for "the stubborn".You have to be lucky that at a certain time of the day to find everything that is still transmitted on it,but also to have devices that lock all the transponders found.
    I'm not sure I found them all,but as you can see,there's still a lot of them I haven't locked up. I don't know how much longer this satellite will be used,but until it's replaced,I'd say that our "performance" will be statistical in nature,i.e. how many of them we'll catch and lock :10:
    In other words this satellite is no longer attractive and we see this by the small number of posts on this forum.
    And yet the signal is strong,as you can see from my pic :51:
  • qwer
    Changed the title of the thread from “24.5°W Intelsat 905” to “24.5°W Intelsat 905 (incl.)”.
  • Here are the transponders found and locked at 24.5W in my area atm,some are with S2x extension,some are generic stream,all are Data:
