1=11459,V,1000,34,32APSK
2=11488,V,10680,56,8PSK---new transponder
3=11518,V,11670,34,NBC_QPSK
4=11528,V,3303,56,8PSK
5=11546,V,15000,56,8PSK
6=11564,V,15150,34,8PSK
7=11595,V,28000,34,8PSK
8=11635,V,32730,56,16APSK
24.5°W Intelsat 905 (incl.)
I cannot lock these transpoders:11058 H,30000,3/4,16APSK and 11084 H,15000,4/5,16APSK.It seems to me that both are stream generic,but I'm not sure.Can you check them?
Thanks -
Sorry satesco, because without Quality on EBSpro...
11182 H 10125 3/4 DVBS- NASA UHD
Here's my general check. Nothing new, I think
Nothing lockable on some peaks via BS -
11495 H,65570,3/4,32APSK
A high symbol rate that I can not lock,probably because of a weak signal,even if it is over 12dB.Maybe you have the luck to see this,it seems, a generic stream?Try and perhaps you can succeed.Anyway it's worth trying.Thanks -
A high symbol rate that I can not lock,probably because of a weak signal,even if it is over 12dB.Maybe you have the luck to see this,it seems, a generic stream?Try and perhaps you can succeed.Anyway it's worth trying.ThanksNot lockable here too.
Okay, great satesco and I will put it into the next GS update...
I exaggerate a little(and not too much),but I would say that this Intelsat at 24.5 W exists only for "the stubborn".You have to be lucky that at a certain time of the day to find everything that is still transmitted on it,but also to have devices that lock all the transponders found.
I'm not sure I found them all,but as you can see,there's still a lot of them I haven't locked up. I don't know how much longer this satellite will be used,but until it's replaced,I'd say that our "performance" will be statistical in nature,i.e. how many of them we'll catch and lock
In other words this satellite is no longer attractive and we see this by the small number of posts on this forum.
And yet the signal is strong,as you can see from my pic
Hat den Titel des Themas von „24.5°W Intelsat 905“ zu „24.5°W Intelsat 905 (incl.)“ geändert. -
The high inclination of the satellite, plus the fact that Intelsat 905 is no longer of interest even for enthusiastic for known reasons, first of all, because the satellite has a high inclination and can only be tracked by those with dual tracking, but also because there are no significant events to report on the satellite.
For this reason, I will post in this section what I found at 24.5W and not at Data, GS, S2X, etc.
And I think it is good to post here ( kind of update) for those who visit us to see what is happening at this position, which has not been visited for two years.
