4079L is Telecafe, moved from 4097, so this should go to t2mi section
Done by qwer. Thanks drhans!
[SIZE=1]Done by qwer. Thanks drhans![/SIZE]
I can confirm this one too. Thanks.
Oops, just a look, drhans before (06.03.17):
Telecaribe HD and Telecaribe HD2 on:
4184 L 5000 3/4 DVB-S2/HD 8PSK, PLP 106
Some Pics with "4T2" from these services.
[SIZE=1]PS: "No DATA arrived timout" with SmartDVB, but no problem with lock...[/SIZE]
Just some Pics from this service.
Sendet Telecaribe HD 2 auf 4184 L 5000 3/4 DVB-S2/HD 8PSK, PLP 106 noch? Ich kann momentan nur Telecaribe HD empfangen.
Grüsse
Fidu
Telecaribe HD 2 hat neu SID 6023 und nicht mehr SID 6022. Damit gehen nun endlich beide Kanäle.
obrigado fidu. Qual modelos sua receptor?
Here's actual situation from my place for T2-MI Frequencies according to my current Report in L.
Some new and some left. Flysat needs update, I think
4183 L 5000 3/4 8PSK – PLP 106 – TELECARIBE 1 E 2
4130 L 3750 3/4 8PSK – PLP 108 – CANAL TRO
4126 L 3750 3/4 8PSK – PLP 102 – CANAL CAPITAL
4111 L 3750 3/4 8PSK – PLP 0 – TELEPACIFICO HD
4012 L 9828 3/4 8PSK – PLP 101 – Señal Colombia HD, Señal Institucional HD, Canal Uno HD Colombia, Radionica, Radio Nacional de Colombia, Señal Digital
4000 L 3750 3/4 8PSK – PLP 103 – CANAL TRECE, CANAL TRECE 2
3887 L 3660 3/4 8PSK – PLP 104 – TELEANTIOQUIA, DATA CHANNEL 6082
3672 L 3750 3/4 8PSK – PLP 107 – TELECAFE’
Telecafé moved from 3672 L to
4096 L 3750 3/4 8PSK - Same PLP 107
Currently Not Lockable from here, very weak:
4130 L 3750 3/4 DVB-S2 8PSK
Maybe temporary...
Maybe temporary...
Possible to lock this one here, but not realy strong signal.
... but I have "silly-waveguide-probs" on this bird, accordigs my last scans in DX>C.
/edit: Content via TBS 6925 and 4T2 (probs to decode video...)
Somebody can check what is the correct T2MI-PLP ID at 4019R SR: 6700?
This should be the RCN package, but without correct T2MI-ID, my blindscan shows just T2MI_RCN.
SR 6700 is correct for 4019R,but unfortunately I couldn't lock it because of the small size of the antenna.
Instead I locked the transponder PLP 3887 L
Hi chucky,
I get same results as you...
Something new appeared, I think - but not sure, probably only data - I can´t check T2-MI content for myself...
4066 L 4280 3/4 DVB-S2 8PSK
Just a complete T2-MI (non) update...
3887 L 4190 3/4 DVB-S2 8PSK – PLP 104 – TELEANTIOQUIA, TELEANTIOQUIA-HD-2
4000 L 3750 3/4 DVB-S2 8PSK – PLP 103 – CANAL TRECE, CANAL TRECE +
4012 L 9828 3/4 DVB-S2 8PSK – PLP 101 – Señal Colombia, Señal Institucional, Canal 1, EXPLOREMOS, RADIO NACIONAL, RADIONICA
[4020 R 6700 5/6 DVB-S2 8PSK ->only data "T2MI_RCN, PDG Service]
4061 L 3750 3/4 DVB-S2 8PSK – PLP 102 – CANAL CAPITAL, EUREKA - CAPITAL
4066 L 4280 3/4 DVB-S2 8PSK PLP 108 – CANAL TRO, CANAL TRO HD2
4100 L 4287 3/5 DVB-S2 8PSK PLP 107 TELECAFE, TELECAFE2
4111 L 4287 3/4 DVB-S2 8PSK – PLP 0 – TELEPACIFICO HD, ORIGEN CHANNEL, Radio_Telepacifico
4184 L 5000 3/4 DVB-S2 8PSK – PLP 106 – TELECARIBE, TELECARIBE PLUS, Sistema Cardinal
