47.7°E Nemesis 1 [P360/PAN]
    As you probably read at Gunter's etc., P360/PAN is a rather "secret" satellite with little info online. Always close to Yahsat 1B at 47.6°, for eavesdropping maybe. You may well be receiving Yahsat instead that also uses the military Ka-band.
    The Satellite Encyclopedia says for P360/PAN: "Has carriers on 20.298, 20.402 & 20.700 GHz."
    OK, thanks hvdh for the details. :73:
    unfortunately, no signal on frequencies mentioned
    20298 20402 20700
    Impossible.
    This is not Yahsat 1B, I am totally sure, when I am at 47.6°, I can't see the 47.7°E frequencies.
    The satellites are very close but in KA band you need to be perfectly aligned.
    Here is the scan of 47.6°E:
    The first scan of 47.7°E (full band)
    both: you see , the strong signal of 47.5° decrease and is nearly not visible when the antenna is at 47.7°
    Am I wrong ?
    Amazing, so much difference when turning just 0.2°! :42:
    Yahsat 1B, I'm sure is at 47.6°E nominal.
    The P360/PAN location is quite uncertain, only based on optical amateur observations like all classified satellites. And often just one TLE every 1 or 2 months (last one: 8 July). Unfortunately, I never backed up old TLE's of these satellites.
    But what I do when a new TLE is issued, is check the average longitude around epoch day, round it to the nearest 0.1°, and update that on my sats.htm page. When I look back old in backups of my page of the last 2 years or so, both 47.6°E and 47.7°E are listed about equally.
    So, a lot of uncertainty. Let's hope for more frequent updates during the dark winter months!
    Original von hvdh
    OK, all clear now with your latest informations about TLE update , maybe it is not exactly 47.7°E but it's very close to 47.5°E .
    :73:
    Finally, today I realized, there are also signals in KA Band A
    between 18300 and 1800 in RHCP and LHCP but nothing found
    (fake scan result)
    any help ?
    Again the question is, can you still separate Yahsat 1B from P360/PAN ?
    Because according TLE's they are very close right now, both near 47.65°E.
    In the early morning should be better with at least 0.1° separation.
    Yahsat 1B has:
    21 * 54 MHz transponders in band 20.2...21.2 GHz, and
    25 * 110 MHz transponders somewhere in band 17.7...20.2 GHz.
    Signals have been reported in band 19.7...20.2 already but surely more sub-bands are used, for a total bandwidth of 2750 MHz!
    Well, today I am more confused for this position, this is not Yahsat it's now sure but according to this new lock in the oposite polarisation, I can read a PID Table referring abot47.5°E, but I repeat, this is not Yahsat 47.5°E , I move a little bit to the east to see the Yahsat spectrumand this is not a satellite in inclined orbit., :88:
    47.7°E (?) in LHCP and RHCP, and just to confirm that is not Yahsat , the spectrum in LHCP
    Nothing really to be confused about, if I understand you correctly?
    P360/PAN is close, but always east of Yahsat as I recall from TLE's.
    And you can separate Yahsat (47.6°E) from P360/PAN (47.7°E).
    Both are not inclined.
    So this 47.5°E mentioned in that table is just a rounded value, not to be taken too literally!
    http://space.skyrocket.de/doc_sdat/nemesis-1.htm
    It has been revealed that this satellite that was codenamed both P360 and PAN (Palladium At Night), is actually the first in a series, named "Nemesis 1".
    The second one "Nemesis 2" was known so far as CLIO.
    CLIO still has a very volatile location like PAN had in the beginning.
    CLIO was seen a month ago at 77.4°E, slowly drifting West. Could be near 75°E now.
    More about PAN: http://spaceflight101.com/snow…mysterious-pan-satellite/
    Nice graph showing PAN eavesdropping on several satellites, before settling at 47.7°E near Yahsat 1B:
    Very interesting link !
    it confirmed what we already talk here, the satellite was always place close to a commercial satellite and now we know the reason why.
    Thanks hvdh for having share this .
    Soon, I will keep an eye on it :11:
    Just my spectrum form position 47.0°E (I think).
    Nothing to lock for me.
    /edit: linear scan.
    Flysat added a Nemesis 1 entry to the list, well done flie!
    The latest (old) TLE of September suggested this satellite is not inclined, but makes daily movements of almost 1°, between 46.75°E and 47.65°E.
    And in this topic, qwer reported both 47.0°E and 47.7°E.
    If this satellite still does that, I wonder how that should be listed at Flysat...
    Take the average position 47.2°E, and replace the text (P360/PAN) with (46.8...47.6°E) maybe?
    See below the longitude/latitude graph of 24 September 2019 (24 hours). Satellite moves clockwise, every dot is an hour.
    Of course it could be different today.
  • Zitat
    Original von hvdh
    thank you very much hvdh for this useful info :73:
    as you said before ; this satellite has not a fixed position..so Flysat decide to delete it ! :37:
    Indeed Nemesis 1 was removed from the Sat List, but the page is still online: https://www.flysat.com/nemesis1.php
    A few years ago, the Sicral satellites were removed, he was a bit reluctant about military satellites, but were put back on my request.
    Meanwhile a new TLE of 16 January has this satellite more stable near 47.6°E, close to Al Yah 2 like it usually was.
    This satellite has been observed drifting away from 47.7°E since the spring of 2021.
    https://sattrackcam.blogspot.c…s-1-is-on-move-again.html
    Still slowly drifting East, near 53.0°E now, and near 53.5°E in 2 weeks.
    Perhaps someone can check in Ka-band C or A, if it is still active during this slow drift?
